Cahill Trials Kid Posted May 24, 2010 Report Share Posted May 24, 2010 Riteee ... So i have Sony Vegas Pro 9 And im just messing around on it trying to get used to it, But when i go to save the file (asif i have made my video and want to save it to a file i can put on youtube, vimeo etc..) It only gives me the choice to save as .. Vegas Pro Pr9odject File (*.Veg) EDL Text File (*.txt) Edit Protocol Compliant (*.aaf) Avid Legacy AAF File (*.aaf) But none of these seem to be the right file type Does anyone no what the file type is called that i need to save it as ? and does anyone no anything you can download to convert files into different types ?? Any help is much appriecated Thanks Sam Quote Link to comment Share on other sites More sharing options...
weirdoku Posted May 24, 2010 Report Share Posted May 24, 2010 Riteee ... So i have Sony Vegas Pro 9 And im just messing around on it trying to get used to it, But when i go to save the file (asif i have made my video and want to save it to a file i can put on youtube, vimeo etc..) It only gives me the choice to save as .. Vegas Pro Pr9odject File (*.Veg) EDL Text File (*.txt) Edit Protocol Compliant (*.aaf) Avid Legacy AAF File (*.aaf) But none of these seem to be the right file type Does anyone no what the file type is called that i need to save it as ? and does anyone no anything you can download to convert files into different types ?? Any help is much appriecated Thanks Sam File>Render As... Make sure you change the bitrate to same as video source, otherwise it will look shit. Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 24, 2010 Author Report Share Posted May 24, 2010 File>Render As... Make sure you change the bitrate to same as video source, otherwise it will look shit. Yes thanks alot mate ! But also where abouts do you change the bitrate, i cant see it, and how do you no what bitrate the video source is ? i no my computer is 32 bit, is this the same thingg ?? Quote Link to comment Share on other sites More sharing options...
weirdoku Posted May 24, 2010 Report Share Posted May 24, 2010 Yes thanks alot mate ! But also where abouts do you change the bitrate, i cant see it, and how do you no what bitrate the video source is ? i no my computer is 32 bit, is this the same thingg ?? 1. Right click on your video file, properties, details, data bitrate. 2. When the window pops up after clicking render as, select the file type you want, then custom. Then change the constant/variable bitrate to as close as your file bitrate. Quote Link to comment Share on other sites More sharing options...
