stunt man t Posted May 24, 2010 Report Share Posted May 24, 2010 hey just bought a DJ and i have no idea about them as i only ride trials could some one please tell me where to get parts from for it what the best and what to stay away from thankyou xxx Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 24, 2010 Report Share Posted May 24, 2010 (edited) hey just bought a DJ and i have no idea about them as i only ride trials could some one please tell me where to get parts from for it what the best and what to stay away from thankyou xxx Backwards, really. What do you have? What do you want to know? Get all parts from www.chainreactioncycles.com. Edited May 24, 2010 by Revolver Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 24, 2010 Author Report Share Posted May 24, 2010 (edited) Backwards, really. What do you have? What do you want to know? Get all parts from www.chainreactioncycles.com. DDG shooter (combat issue) rock shox psylo forks 100mm fsa the pig headset truvative cranks massive 46t frt chain ring with dh tensioner thingy 8 speed mavvic rims (thin as fooooook) magura julie frt and rear brakes 160mm rubbish tyres bars and stem just want some new parts as there all quiet old lol Edited May 24, 2010 by stunt man t Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 24, 2010 Report Share Posted May 24, 2010 Second hand? Psylo forks, haha, those aren't new Most of that will do until you break it, really. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 24, 2010 Author Report Share Posted May 24, 2010 (edited) Second hand? Psylo forks, haha, those aren't new Most of that will do until you break it, really. yeah james sold it me allways wanted a shooter so i couldnt say no thanks for the help mate xxxx Edited May 24, 2010 by stunt man t Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 24, 2010 Report Share Posted May 24, 2010 DDG shooter (combat issue) rock shox psylo forks 100mm fsa the pig headset truvative cranks massive 46t frt chain ring with dh tensioner thingy 8 speed mavvic rims (thin as fooooook) magura julie frt and rear brakes 160mm rubbish tyres bars and stem just want some new parts as there all quiet old lol Get NS bars mate, atomlab or halo rims are top notch, i would only keep the rear brake, also i would chuck some bmx cranks on it with 28t, not alot i would do without changing the framee. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 24, 2010 Author Report Share Posted May 24, 2010 Get NS bars mate, atomlab or halo rims are top notch, i would only keep the rear brake, also i would chuck some bmx cranks on it with 28t, not alot i would do without changing the framee. i want to keep the frame as ive allways wanted it since it came out 10 million years ago thanks for the advice though mate ill look for them bars etc Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 27, 2010 Author Report Share Posted May 27, 2010 (edited) right ive decided to upgrade the brakes wheels and drivetrain first i want to put 203mm discs on it front and rear atm the rear is 160mm and the frt is 180mm im going to buy them new, but will they go straight on or will need to get something to make them fit?? im going to run it single speed so i need to change the cranks and the wheels would it be ok to get the wheels off tarty or stick to dj stuff?? what is the best gear ratio to run if im using it for dirt jumping? thanks xx Edited May 27, 2010 by stunt man t Quote Link to comment Share on other sites More sharing options...
stoozie Posted May 27, 2010 Report Share Posted May 27, 2010 right ive decided to upgrade the brakes wheels and drivetrain first i want to put 203mm discs on it front and rear atm the rear is 160mm and the frt is 180mm im going to buy them new, but will they go straight on or will need to get something to make them fit?? im going to run it single speed so i need to change the cranks and the wheels would it be ok to get the wheels off tarty or stick to dj stuff?? what is the best gear ratio to run if im using it for dirt jumping? thanks xx Use chain reaction cycles, quick postage and really reliable, they'll also have more options for you on what you want to get. Also, why the hell do you need a front brake? Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 27, 2010 Author Report Share Posted May 27, 2010 Use chain reaction cycles, quick postage and really reliable, they'll also have more options for you on what you want to get. Also, why the hell do you need a front brake? cheers mate why not? Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 27, 2010 Report Share Posted May 27, 2010 im going to buy them new, but will they go straight on or will need to get something to make them fit?? im going to run it single speed so i need to change the cranks and the wheels would it be ok to get the wheels off tarty or stick to dj stuff?? what is the best gear ratio to run if im using it for dirt jumping? thanks xx On CRC it will give you the option to buy a 203mm brake, which means it should come with everything to be 203mm. For wheels, you can buy rims like spank rims or atomlab rims. Sun rims are also good. For hubs, if you're going for rear freehub there's nothing stopping you using a pro II trials, seeing as you're going for singlespeed. If you want a screw-on hub, DMR revolvers are decent. Ratio is something like 32:16. Quote Link to comment Share on other sites More sharing options...
stoozie Posted May 27, 2010 Report Share Posted May 27, 2010 cheers mate why not? Just i've never run one on mine, and I've never seen one apart from brand new out the box with a front brake on, thats all. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 27, 2010 Report Share Posted May 27, 2010 Also, why the hell do you need a front brake? A front brake provides loads better stopping power than a back brake. Versatility, innit. It's pretty useful for BSX. Quote Link to comment Share on other sites More sharing options...
stoozie Posted May 28, 2010 Report Share Posted May 28, 2010 A front brake provides loads better stopping power than a back brake. Versatility, innit. It's pretty useful for BSX. Meh, I've never run one I do see your point though. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 28, 2010 Report Share Posted May 28, 2010 Meh, I've never run one I do see your point though. I don't use one either, ha. Quote Link to comment Share on other sites More sharing options...
