Spacing Issues....
Alex Dark
Yeee so basically changed forks to run a disc...problem is the rotor rubs horrendously on the CPS bolts and the inside of the caliper (nearside) are there any known issues about the urban forks with a king hub? Tried two different adaptors..and the same woes ensued.
Im assuming the Echo forks just have a mount thats welded on a smidge too far towards the hub...so i guess my only option is to mill down the adaptor to bring both caliper and bolts slightly toward the outside of the fork leg...anyone else have any good ideas?
PS tried washer on the axle of the hub, but even with a decent sized 1mm it wont quite clear.
