dann2707 Posted May 21, 2010 Report Share Posted May 21, 2010 Howdy. I've just been out on my t-pro to notice that every one or two full pedals I get this weird wobble, almost like a skip that I feel on my feet. I only just got my t-pro (2007) yesterday so I'm all new to this stuff again after a nice 4 year gap! What could be the problem? And also whislt i'm making a thread, I have an issue with my hs11 on the rear, the pistons do not move until a certain amount of leverage is given! The brakes are as far as they can be up against the rim and even at that there is at least a 4mm gap on the left side of the rim wall. And to add to this problem the piston doesn't seem to move until I pull a certain amount as mentioned above. I've even drawn a pretty little picture on paint to show what I mean! haha. I've done a search but to no avail. Help would be really appreciated as I'm all new to this again!! Many thanks, Dan Picture: Quote Link to comment Share on other sites More sharing options...
Borat Posted May 21, 2010 Report Share Posted May 21, 2010 There could be a million things to do with the skipping mate. But, with the brake, it either needs a bleed, or you can ajust the little allen key hole, which pushes the piston in further. It's the allen key hole which is one the lever blade, if you look straight downwards the lever, you will see it. Turn it to the right a couple of times, untill your desired movement. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 21, 2010 Author Report Share Posted May 21, 2010 Great stuff! Cheers for the fast reply. I'll give the latter ago tomorrow and see how I get on. Just need some advice on the wobbly crank now. Quote Link to comment Share on other sites More sharing options...
Borat Posted May 21, 2010 Report Share Posted May 21, 2010 As for the wobby crank. Are they the onza cranks? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 21, 2010 Author Report Share Posted May 21, 2010 As for the wobby crank. Are they the onza cranks? Yes sir. All standard as far as I can tell. I know for sure it's the ACS freewheel too. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted May 21, 2010 Report Share Posted May 21, 2010 For the brake: Bleed! With water! For the pedal: -Check if your pedal is tight -See if your chain is tensioned enough (otherwise it can skip pretty easily) -Check your freewheel (because it could be it skipping) -And last but not least, check your Bottom Bracket, Sometimes when it's not tightened up, it can cause quite a lot of wobble! Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 21, 2010 Author Report Share Posted May 21, 2010 For the brake: Bleed! With water! For the pedal: -Check if your pedal is tight -See if your chain is tensioned enough (otherwise it can skip pretty easily) -Check your freewheel (because it could be it skipping) -And last but not least, check your Bottom Bracket, Sometimes when it's not tightened up, it can cause quite a lot of wobble! Thanks for that buddy :'D I really wish there was a "thanks" button on this forum like there are on other forums! Dan Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 22, 2010 Author Report Share Posted May 22, 2010 I have solved the rear maggy problem thanks Borat using the method you said. Now onto tightening the freewheel. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted May 24, 2010 Report Share Posted May 24, 2010 (edited) The crank could be rounded ... If it is, it's to get another one (prosumed it''s square taper) Edited May 24, 2010 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
