Magura Problem
staphan
When braking, the wheel is pushed noticeably to one side. Why is this happening? How can one side of the brake be "weaker" than the other?
Thanks!
Edit: Or maybe it's not the Magura itself that is the problem, I don't know.
Edited by staphan
is your wheel dished correctly?
It's built by the guys at Tartybikes and not used for more than a couple of hours, so I'd guess it is. (not sure what "dished" means but I suppose it has to do with proper spoke tension)
Edited by staphan
maybe you have a week cylinder?
Check if your pads are close to the rim. If they arnt close, one will push harder than the other.
>_<
It's probably just a sticky seal. And obviously check that the bearings are free from play and that the wheel is tightened.
If everything is done up properly and it still happens, your brake needs some TLC
