zoo python luke Posted May 19, 2010 Report Share Posted May 19, 2010 hey all got a grind on my echo urban rim but i want a smooth rim again is it possible to smooth a rim or do i have to get a new one? thanks Quote Link to comment Share on other sites More sharing options...
Riley1 Posted May 19, 2010 Report Share Posted May 19, 2010 Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted May 19, 2010 Report Share Posted May 19, 2010 Yeah, it's possible but really not worth the hassle! Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted May 19, 2010 Report Share Posted May 19, 2010 You guys shouldn't bother replying. He asked for your help not your opinion, he wants a smooth rim so let him have one. Use sandpaper to smooth your rim, start slightly rough to wear the grind down and slowly move onto finer and finer sand paper untill its back to smooth, give it a clean to get rid of the metal dust and you're done. ^^ Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 19, 2010 Report Share Posted May 19, 2010 Just leave the grind, they go dull after a while, which is as good as smooth. Depends on the state of the grind at the moment though. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 19, 2010 Report Share Posted May 19, 2010 Back in the day, I found if you didnt do a proper job on it and just left it slightly rough, you'd have a worse brake than if it was completely smooth or fully ground. So make sure you spend some time and do it properly... A belt sander could help the process. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted May 19, 2010 Report Share Posted May 19, 2010 nice one. Different grades of sand paper/wet and dry and a sander/dremel Quote Link to comment Share on other sites More sharing options...
TOBY-E Posted May 19, 2010 Report Share Posted May 19, 2010 nice one. Different grades of sand paper/wet and dry and a sander/dremel just put a sanding pad on a angle grinder takes about 2 mins. saves fukin round with sandpaper. Quote Link to comment Share on other sites More sharing options...
Ipod Bob Posted May 19, 2010 Report Share Posted May 19, 2010 took me an hour with sandpaper once, it was EPIC but possible Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted May 19, 2010 Report Share Posted May 19, 2010 i took the paint off my rim with a file and that was so fine it took about 10 mins to go smooth, i would just take the tire off, put the wheel in the frame and file it down on both sides. chris Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted May 19, 2010 Report Share Posted May 19, 2010 On tarty bikes on the product guide for rim grinding it says if you grind the rim both ways it just smothes it off, so i would think you could just do it the opporsite way to the grind and it should work. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 19, 2010 Report Share Posted May 19, 2010 No, that'll just result in a shit grind. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 20, 2010 Report Share Posted May 20, 2010 No, that'll just result in a shit grind. haha werd Quote Link to comment Share on other sites More sharing options...
