Echo Sl Freewheel
N.Wood
Might have to take my freehweel apart to grease the (open) bearing and clean/check the pawls and all.
So... I the lockring standard or reverse thread?
Are the ball bearings in a cage or will they fall out under my fridge with the old sweetcorn?
Cheers now.
Cheers now.
They'll fall out and all over the shop. Is it skipping? I'm pretty sure the thread is just a normal thread too.
Not skipping, but I ride in alot of coastal areas and the bearings sound pretty rough along with a fair bit of side to side play (lockring is tight - wouldn't move either way when we tried last, though wernt 100% whether it was reverse or not)
You could always soak it in a bath of paraffin over night and then a bath of thin oil, occasionally taking it out and giving it a spin; not saying it will get all the crap out but its probably the best you will do if you cant strip it :)
Yeah, trouble is the bearing could do with grease and the pawls could do with a thin oil o without taking it apart its a bit of a b*****d. Will try it if thats my only choice though (Y)
To be honest oil would just as good for the bearings than grease, for the mileage that it covers I would expect a re-oiling every 6 months would be more than sufficient. You say the bearing has some play in it already? Might be a bit late to add oil now, depends on how much play youre happy to ride with :)
This reminds me, its about time I serviced my king, not been done in over a year :D
Yeah, trouble is the bearing could do with grease and the pawls could do with a thin oil o without taking it apart its a bit of a b*****d. Will try it if thats my only choice though thumbsupanim.gif
I was told by Adam from tarty bikes that the SL doesn't have any grease in, it's only lightly oiled inside so I wouldn't worry too much about greasing the bearings. A bit of thin oil should do the trick with it!
Hmmm... Well, the bearings rattle around when its shaken and makes clunking noises every revolution (not pawls, happen with cranks spinning with the wheel).
Other than that its working fine.
Mine rattles when you shake it but never had a problem.
Sounds to me like the races are well and truely shafted, thats of course assuming the outer ring isnt loose in the 1st place (Im used to a king that never has any looseness and never used a freewheel). I guess as long as its not skipping it shouldnt be a problem, having constant clunk would annoy the hell out of me though :D
Sounds like some grit in there possibly. They are pretty easy to service as long as you are careful, just open it up inside a bucket or tray (Y)
There's a 'gap' in the bearings to allow the freewheel to rotate without binding, but you could *maybe* put one extra in each side to reduce the rattling.
The other way would be soak/blast it as has been said above, then dribble some gloopy chain lube into the bearings, that should stick them into place like grease.
Wurth motorcycle chain lube is fantastic stuff, liquid which then solidifies to grease. Not sure I would want it in the pawls though, are the bearings significantly seperate or are they likely to cross contaminate?
Yeah blasted it all out with GT 85, before I did it there was a gritty noise but after seemed fine.
Might try some lube in there. Works fine, but the noise is a bit disconcerting. Is the lockring normal or reverse thread Ad?
Cheers.
