Dougal Posted May 17, 2010 Report Share Posted May 17, 2010 When I first started riding with my Onza Ice it had a Magura Louise disk on the front. This soon changed to a Magura HS33 which seems to hold a lot better for me. However my forks are sure to give up on me in the next few weeks, I thought it would be best to find out some opinions on the reversed Magura mounts on 20" forks such as the Try-All Forxx. Many Thanks. 1 Quote Link to comment Share on other sites More sharing options...
KurtiisBrookhouse Posted May 17, 2010 Report Share Posted May 17, 2010 You know when you say reversed, do you mean when the mounts are on the back of the forks? Kurtis(Y) Quote Link to comment Share on other sites More sharing options...
Dougal Posted May 17, 2010 Author Report Share Posted May 17, 2010 You know when you say reversed, do you mean when the mounts are on the back of the forks? Kurtis(Y) Yes thats what I meant by it :$ is that not the correct term then because me and my friends have always called them reversed mounts. Thanks, Dougal Quote Link to comment Share on other sites More sharing options...
KurtiisBrookhouse Posted May 17, 2010 Report Share Posted May 17, 2010 (edited) No its fine its just that i wasn't sure. Kurtis Edited May 17, 2010 by t-comp-kurtis Quote Link to comment Share on other sites More sharing options...
trials owns Posted May 17, 2010 Report Share Posted May 17, 2010 (edited) When I first started riding with my Onza Ice it had a Magura Louise disk on the front. This soon changed to a Magura HS33 which seems to hold a lot better for me. However my forks are sure to give up on me in the next few weeks, I thought it would be best to find out some opinions on the reversed Magura mounts on 20" forks such as the Try-All Forxx. Many Thanks. yay first time i have seen u on the forum, u should be validated soon , bit sad tc is selling his zona, cant pm u because your still a pre member so randomly writing here, sorry for pissing your thread up. how comes your forks are going to give up but yeah i was wondering the other day why the mounts are backwards on most forks, must be some reason. Edited May 17, 2010 by trials owns Quote Link to comment Share on other sites More sharing options...
jt123 Posted May 17, 2010 Report Share Posted May 17, 2010 They pull the braking force into the forks, rather than away from them. This gives more braking power, yet the forks are more prone to cracking around that area as there is a fair bit more stress put on that area. Quote Link to comment Share on other sites More sharing options...
Guus Bouwmans Posted May 18, 2010 Report Share Posted May 18, 2010 They pull the braking force into the forks, rather than away from them. This gives more braking power, yet the forks are more prone to cracking around that area as there is a fair bit more stress put on that area. exactly. They should actually make a plate there similar to a brakebooster, which spreads the stress over a larger surface area, and it will also reinforce the welds on the back of the forks too (which always tend to crack at my forks). I have no idea if anyone has tried that already, but I think that would solve that problem right? (please excuse the English, I'm Dutch) Quote Link to comment Share on other sites More sharing options...
