zoo python luke Posted May 17, 2010 Report Share Posted May 17, 2010 morning all can this brake be used as a rear or front, or do you need a front for the front and a rear for a rear? thanks Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 17, 2010 Report Share Posted May 17, 2010 The parts are identical apart from the hose. Obviously a front brake will not have a long enough hose to reach the rear. Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 17, 2010 Author Report Share Posted May 17, 2010 (edited) The parts are identical apart from the hose. Obviously a front brake will not have a long enough hose to reach the rear. so if i buy a front and some hose. it will work fine on the back, after i bleed it obv. and can i bleed it with water? thanks for the quick reply Edited May 17, 2010 by zoo python luke Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 17, 2010 Report Share Posted May 17, 2010 Yes. You can't use water. Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 17, 2010 Author Report Share Posted May 17, 2010 Yes. You can't use water. maggie blood? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 17, 2010 Report Share Posted May 17, 2010 Yep maggie blood is fine. As is Citroen LHM mineral oil. Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 17, 2010 Author Report Share Posted May 17, 2010 thanks for you help, Quote Link to comment Share on other sites More sharing options...
