mckenzietrials Posted May 16, 2010 Report Share Posted May 16, 2010 Hi there I have Hs33 the problem is my TPA system (the red dial) is stuck and will not turn ?? I have taken the lever out of the cyclinder and it still wont turn ?? Any help ?? thanks mckenzie Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted May 16, 2010 Report Share Posted May 16, 2010 I Had this problem aswell. This is no help whatsoever because i cant remember how i fixed it, because it wasnt me that did it! all i say is dont buy a new tpa or lever as it can be fixed. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted May 16, 2010 Report Share Posted May 16, 2010 Take your lever blade of the body, and remove the push rod from the tpa, I know you said it wont turn but with a set of pliers believe me it will turn. once you have the red bit in your hand inspect the threads to make sure they are not knackered. Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 16, 2010 Report Share Posted May 16, 2010 If its the standard plastic red TPA the they are renowned for stripping the threads, get yourself a metal CNC TPA and you'll be sorted Quote Link to comment Share on other sites More sharing options...
