Freewheel Skipage
trials owns
hi everyone
about a couple of month ago i bought a tensile 60 click and now it is starting to skip and make a loud noises like every 5 mins, same story for my previous freewheel i had (rockman 72 click) what am i doing wrong? any ideas how i can stop this skipping happening?
cheers
hi everyone
cheers
Lock ring tight?
oh i see now how often do i need to do that?
thanks
So it never comes loose. Check it at least once a week! You dont have to take the crank off to tighten/check it.
I use a flat head screw driver with mine. Just jam it in and push it round (anti-clockwise) till its tight.
Buy an SL or TR ;)
EDIT: For a useful answer - the Tensile pawls seem to round off a bit when the freewheel starts skipping every now and again, which exacerbates the problem a bit. Strip it down, clean out any shards of pawl floating about in there and give the pawls a look. Spin the freewheel around with the lockring and one bearing off and see how neatly the pawls click into the ratchet. If they're not really sitting in there very well, it might be worth buying some new pawls to get them digging in properly again.
Buy an SL or TR ;)
cheers everyone
