stooie Posted May 14, 2010 Report Share Posted May 14, 2010 Hi guys i have been trying to get my head round this technique for a while and i am really struggling with it i just cant seem to get the bike forward quick enough to complete the move and usually end up as a heap of bike and person on the floor ! would changing from a 90 mm 10 degree rise to say a100 or 115 mm with a bigger rise help or am i being a bad workman and blaming my tools ? any advise would be greatly appreciated ! Quote Link to comment Share on other sites More sharing options...
L8ON J Posted May 26, 2010 Report Share Posted May 26, 2010 I learnt this 2 days ago I had ago on my friends high spec limey 320 and tryed it on that and somehow I did it first time. But when I tryed it on my low spec t pro it feels ALOT different. So it could be your bike restricting you? I can do it now but I did it by starting small, doing a small wheelie up it, holding the front brake, but then when you drop onto your back wheel, when you halfway down I transfer my body weight to a hop to the back wheel, and then pushing on the cranks to lift the bike up. Hope this helps Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted May 26, 2010 Report Share Posted May 26, 2010 Hi I have found that if you use a paving slab or something of equal ish length and do an endo then try and force your back wheel down and lift your bars up your rear wheel will nine times out of ten land where your front wheel was then its just a case of practice practice practice and move on to smaller higher objects dont blame the bike it will hurt you . Hope this helped. Quote Link to comment Share on other sites More sharing options...
hulud Posted May 27, 2010 Report Share Posted May 27, 2010 which move are you asking about exactly? Quote Link to comment Share on other sites More sharing options...
chris4stars Posted May 27, 2010 Report Share Posted May 27, 2010 http://www.trashzen.com/biketrial-wheel-swap.php personally, the explanations on here so far just went clear enough...no offence guys Quote Link to comment Share on other sites More sharing options...
