Pads Questions
Canardweb
Hello, I would like to ask a little something: I have switch from a smooth trialtech double walled rim to my NoWar try-hole rear rim with a medium grind, and my Heatsink yellow pads don't make noise (except when I ride fast and feather the brake).
For example, when I want to get on my rear wheel, it makes more a rubbing noise than a honk. Is that normal? Because I have never ridden these pads on a grind before.
Get Tnn's..
Sorry I'm no help. ;)
from what i have heard they are loud, how long have you had the pads ? because they might not of bedded in yet and are they set up square onto the rim ? are the pads clean? do they perform well becasue if they do i wouldnt change it becasue it gets on my nerves lol, if im doing a manual or soemthing and i drag the back brake or tap the brake to get the front down a bit it makes a annoying noise :/
chris
chris
They are setted perfectly straight, they are clean, but I have ridden my bike for 20 minutes and the pads were brand new... Could this explain that? How long do the Heatsink yellows take to bed in?
ye there not bedded in yet but just give it time and they will be fine, it depends what your doing realy, my coasts took about 1 hour on a grind but i dont know about how long for yellowsm if you just ride you will feel a difference, they will start to make noise and will hold alot better. hope i have helped.
chris
chris
My cousts never had to bed in, they were perfect when I setted them as brand new. And their performance never changed...
My yellows were pretty noisy from the outset, they were also awesome straight away; the bedding period just seemed to be whilst the pads quickly wore to the shape of the rim. If the brake works now but its quiet then even better, I miss the old koxx browns that would swoosh rather than honk :)
A noisy brake doesnt equal a working brake.
No worries, I am back to the Coust! as the Heatsink never bedded in after an 8 hour ride...
Thats really unusual, mine started working straight away, Ive found that all of my heatsink setups have worked better with slightly more flex than on stiffer frames. I had reds on my hifi and with a 4bolt booster on there it had zero bite or hold, took the booster off (just using the built in one) and the brake was phenomenal. When I got the triton I put the 4 botl back on as I was worried about the ti frame flexing too much, again there was zero hold but a little more bite, ditched the 4bolt for a small carbon 2 bolt and it works perfectly. I find the flex allows the pads to bite and hold better.
IIRC youre using a vee setup, presumably with a booster, try taking the booster off and see if it helps; could also be related to the fact that vee pads cant 'roll' and bite like magura ones can.
HONK! HONK!
I found some random blue magura backed pads in my pile of trials crap, that don't honk, but they f**king work amazing, have no idea where they came from either, they even hold amazing when my buddy was riding with the rims soaking wet (It was very annoying, stoopid broken ankle).
Absolutely no idea what they are.
HONK! HONK!
get a pic up ?
