Cahill Trials Kid Posted May 12, 2010 Report Share Posted May 12, 2010 (edited) Rite so im bleeding my magura hs33 for the first time, Im using water, and ive done exactly what people have told me to do, but when i press the lever (after finishing the bleed and screwing everything back on) its like theres no fluid in there at all, the pads just stay still. Ive not actualy got the brake attached to the bike at the minute, could this be affecting it ? This is what i am doing ... im filling my syringe with water, i am then attaching to my pipe (that has the bit you screw into the brake init) Im then undoing the screw on the brake and screwing the screw in the pipe into the brake, Im then completely un screwing the other bleed screw on the leaver Im then pushing the syringe slowly untill almost all the water has left and just letting the water drip out of the leaver, Im then taking all the syringe and pipe ect. off and screwing the screw back into the brake, and then the same with the screw on the leaver. I have now just read this, and i seem to being doing everything rite, but i have no idea what it means by the first bit about the TPA, what is a TPA ?? wiki Any help needed, Thanks Sam EDIT : sorry if you find this hard to understand, im shite at explaining things Edited May 12, 2010 by Cahill Trials Kid Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 12, 2010 Report Share Posted May 12, 2010 TPA is the red bit on the lever blade. Unscrew it (anti clockwise) all the way before you start the bleed. Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 12, 2010 Author Report Share Posted May 12, 2010 TPA is the red bit on the lever blade. Unscrew it (anti clockwise) all the way before you start the bleed. Thanks ALOT ! I think thats what it will be, will try and bleed it again in a minute Thnkyouu Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 12, 2010 Author Report Share Posted May 12, 2010 (edited) just tried the bleed again, with the TPA completely undone and its still the same, the pads just dont move at all Edited May 12, 2010 by Cahill Trials Kid Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted May 12, 2010 Report Share Posted May 12, 2010 Try putting in the bleed screw where the water comes out before you unscrew the syringe after bleeding, hopefully, this will stop any fluid coming out of anywhere, then just be careful when unscrewing the syringe, and keep everything exactly still while you screw in the other bleed screw I hope I explained that okay? If you need any more help, PM me. Alex. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 12, 2010 Report Share Posted May 12, 2010 Dont completely undo the bleed screw at the lever end, just undo it enough to let a small amount of air/water out. works for me Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 12, 2010 Report Share Posted May 12, 2010 If you're using water then just do a bath bleed, no real way to get it wrong then Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 12, 2010 Author Report Share Posted May 12, 2010 If you're using water then just do a bath bleed, no real way to get it wrong then Really could not work out what i was doing wrong the syringe way, just tryed it in the bath and it seems to of done Cheers Sam Quote Link to comment Share on other sites More sharing options...
psycholist Posted May 12, 2010 Report Share Posted May 12, 2010 If you pump the water in really slowly it can leave bubbles in the system that would be entrained in the fluid and come out if you pumped it through faster. Make sure you're bleeding from the lowest point in the brakes to the highest. The second slave piston is usually where the bubbles end up, so make sure the pipe from the slave to the brake lever is the highest point on that slave piston. On the more recent Maguras I found that bubbles stayed in the lever unless I pumped the lever slowly a few times while filling, so this is worth a try too. Quote Link to comment Share on other sites More sharing options...
Ollied Posted May 12, 2010 Report Share Posted May 12, 2010 Also, make sure you've thoroughly flushed the fluid of all oil. Quote Link to comment Share on other sites More sharing options...
