zoo python luke Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) hey all, just what to know weather i should have a grind or keep a smooth rim for these pads. dont really like grinding my rim, but if i have to i will what do YOU have, and how are they?? Edited May 11, 2010 by zoo python luke Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 11, 2010 Report Share Posted May 11, 2010 First of all theres, a thred just abit further down the trials chat part about these pads, but use a grind, always use a grind for any pad you use Quote Link to comment Share on other sites More sharing options...
Nick Melson Posted May 11, 2010 Report Share Posted May 11, 2010 I ran them with a tiny bit of a tar on a smooth rim and they were amazing. But then i have heard people say with a grind there amazing so its down to personal preference really , run them smooth for a week or two and if there not to good give it a grind. Quote Link to comment Share on other sites More sharing options...
monty-james Posted May 11, 2010 Report Share Posted May 11, 2010 So either way they are amazing really. With a smooth rim, use a bit of tar or have a grind? Im considering getting some, will a heavy grind mangle these pads? Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 11, 2010 Author Report Share Posted May 11, 2010 So either way they are amazing really. With a smooth rim, use a bit of tar or have a grind? Im considering getting some, will a heavy grind mangle these pads? ??? Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) but use a grind, always use a grind for any pad you use Or just learn how to control your landings, set your brake up properlly in the first place and actually pull it..... Works for me. For now, I would keep it smooth, set up your brake perfectly and try it for a bit. See how you get on, if you don't like it then grind it. Edited May 11, 2010 by Trials Punk Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 11, 2010 Author Report Share Posted May 11, 2010 (edited) Or just learn how to control your landings, set your brake up properlly in the first place and actually pull it..... Works for me. For now, I would keep it smooth, set up your brake perfectly and try it for a bit. See how you get on, if you don't like it then grind it. yeah, i think ill do that. but if i do decide to grind the rim, how long will the pads last?? Edited May 11, 2010 by zoo python luke Quote Link to comment Share on other sites More sharing options...
forteh Posted May 11, 2010 Report Share Posted May 11, 2010 yeah, i think ill do that. but if i do decide to grind the rim, how long will the pads last?? Mine are lasting really well with a medium grind, once they have bedded in the firs 2mm or so (happens quite quickly) they seem to last for ages; I wouldnt like to comment on a harsh grind though. Mine work 100%, not let me down yet Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted May 11, 2010 Author Report Share Posted May 11, 2010 thanks everyone, think ill try them on a smooth rim and grind it if need be. Quote Link to comment Share on other sites More sharing options...
BlueSmokeyJoe Posted May 11, 2010 Report Share Posted May 11, 2010 The key, I've found is having a light to medium sharp grind. Had my pads about 8-9 months riding once or twice a week on average and they are about a third worn? (and that includes a bit of sanding just to keep them perfectly square as they wore at a very slight angle once or twice) Hope this helps you! Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 11, 2010 Report Share Posted May 11, 2010 Or just learn how to control your landings, set your brake up properlly in the first place and actually pull it..... Works for me. For now, I would keep it smooth, set up your brake perfectly and try it for a bit. See how you get on, if you don't like it then grind it. A grind makes your brake alot better, without having to use tar ect.. so why wouldnt you A grind is also so sooo much better in wet weather Quote Link to comment Share on other sites More sharing options...
