stunt man t Posted May 10, 2010 Report Share Posted May 10, 2010 (edited) basicaly i want to strip the paint off my frame ive got lots of nitromors, so i can make a start problem is though, what do i use to pull it all off? in the past on my old frame i used about 7 brilo pads, once the paint had bubbled but i dont have any at home now and i wanna start it now! is there any thing else i can use or will have to wait till i can be botherd to go to the shop and buy some more brilo pads? thanks xxxxx Edited May 11, 2010 by stunt man t Quote Link to comment Share on other sites More sharing options...
Mikee Posted May 10, 2010 Report Share Posted May 10, 2010 (edited) you can sometimes just put the nitromors on for abit and scrape the paint off with an old top-up card or something else just as stiff depending on the quality of the paint. It has worked for me a few times, so I would suggest giving that ago. Edited May 10, 2010 by Mikee Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 10, 2010 Report Share Posted May 10, 2010 I just used the brush when I did mine at work the other night. Paint a bit of the bike with it, let it go off for a bit then paint a bit more over it and as you do if you push down firm it takes the old off then rinse that section with water whilst brushing it down to get rid of the last bits. Worked a treat for me! Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 10, 2010 Author Report Share Posted May 10, 2010 I just used the brush when I did mine at work the other night. Paint a bit of the bike with it, let it go off for a bit then paint a bit more over it and as you do if you push down firm it takes the old off then rinse that section with water whilst brushing it down to get rid of the last bits. Worked a treat for me! wicked thanks mate ill just do that and then use mikee's help for all the hard to reach places thanks xx Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 10, 2010 Author Report Share Posted May 10, 2010 i dont no what onza painted this frame with but the brush wont budge it its very deep Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 10, 2010 Author Report Share Posted May 10, 2010 ive used the flat side of a junior hacksaw blade, works fine frame looks beast in silver Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 10, 2010 Report Share Posted May 10, 2010 Hahaha just dont get it in your eyes, my brother flicked a brush at me that had nitromors on it and it stang like a bitch Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 11, 2010 Author Report Share Posted May 11, 2010 right i give up!!! gonna buy some brillo pads tomorrow as everything else is useless see..... Quote Link to comment Share on other sites More sharing options...
Barnesy Posted May 22, 2010 Report Share Posted May 22, 2010 basicaly i want to strip the paint off my frame ive got lots of nitromors, so i can make a start problem is though, what do i use to pull it all off? in the past on my old frame i used about 7 brilo pads, once the paint had bubbled but i dont have any at home now and i wanna start it now! is there any thing else i can use or will have to wait till i can be botherd to go to the shop and buy some more brilo pads? thanks xxxxx If i was you i would find a local sand blaster and get your frame sand blasted, They would only charge about £20 and it would be a perfect job. I do sandblasting where i work and i'v done loads of frames, they have always come out great i would do it for you but i live on the isle of wight but i hope this info helps Quote Link to comment Share on other sites More sharing options...
