modifiedridah2k9 Posted May 10, 2010 Report Share Posted May 10, 2010 Hey guys, nothing about my trials but today i was riding my saracen to school and on the way back my mate bashed into it accidently and it is buckled very badly. Me and my mate have just completly battered into the rim but it doesnt seem to get much better,we were kicking it for 10 mins but still badly buckled. So how do i make it completley straight without spending money? any help is great as it is annoying me so much, if it was my trials bike i would be battering it for hours until it was perfect but thankfully its not lol cheers, Kieran Quote Link to comment Share on other sites More sharing options...
BlueSmokeyJoe Posted May 10, 2010 Report Share Posted May 10, 2010 Hmmm, take the wheel off and then remove the tyre/tube and try and straighten out the bend, then have a tweak with the spokes to try and true it as much as possible...... Quote Link to comment Share on other sites More sharing options...
liam1992 Posted May 10, 2010 Report Share Posted May 10, 2010 Well for a start stop kicking it and buy a truing tool and watch a video of how to true a wheel thats you best bet or just buy a new rim. Quote Link to comment Share on other sites More sharing options...
TROYston Posted May 10, 2010 Report Share Posted May 10, 2010 You done one of two things there: 1-Bent the rim and/or made it worse. 2-just made it more buckled. Get a spoke key, if on budget use a small adjustable; and true your wheel, If you don't know how to, youtube it. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 10, 2010 Report Share Posted May 10, 2010 Well for a start stop kicking it as if that was gonna fix it Quote Link to comment Share on other sites More sharing options...
liam1992 Posted May 10, 2010 Report Share Posted May 10, 2010 as if that was gonna fix it Well he said he was battering it so i assumed he was kicking hence why i said "for a start STOP kicking it " Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted May 10, 2010 Author Report Share Posted May 10, 2010 as if that was gonna fix it Well it helped a little. Bashing it helps it Quote Link to comment Share on other sites More sharing options...
trials owns Posted May 10, 2010 Report Share Posted May 10, 2010 as if that was gonna fix it saw some bloke smash it against a tree on youtube and made it alot better, but never fixed it properly. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted May 10, 2010 Author Report Share Posted May 10, 2010 saw some bloke smash it against a tree on youtube and made it alot better, but never fixed it properly. Yeah it does the job until you get the money to tru it Quote Link to comment Share on other sites More sharing options...
psycholist Posted May 10, 2010 Report Share Posted May 10, 2010 Once the rim has bent it's almost impossible to get it running properly straight again. Properly straight would be straight enough that rim brakes work perfectly smoothly on it. If the wheel is a little bit out, but local out of trueness is below half a cm and the overall buckle is spread around the whole wheel it might be savable. Starting at the valve hole (This means that when you get to the valve hole again you've definitely made a full round) loosen all the spokes 2 turns and then see about bending the rim back. Trying to do this with the spokes at full tension will pretty much always make things worse. Once the rim is straight put one turn of tension back and then see about truing the wheel... 1 Quote Link to comment Share on other sites More sharing options...
