Rowlly21 Posted May 10, 2010 Report Share Posted May 10, 2010 Hi Is a V-brake booster worth getting for my v brakes that dont hold pervect but do the job, Will a brake bosster give it the extra touch or no point what so ever. Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 10, 2010 Report Share Posted May 10, 2010 Depends, if they flex the frame/forks out when you pull them on you may see some improvement but other than that its probably an upgrade to hydros. Have you ground your rim or owt as well as that may help! Quote Link to comment Share on other sites More sharing options...
Rafal Posted May 10, 2010 Report Share Posted May 10, 2010 without a booster you will kill the frame, sooner or later. It will start to break under the mounts Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 10, 2010 Report Share Posted May 10, 2010 I found using a vee booster improved the hold no end, strongly recommend one. Quote Link to comment Share on other sites More sharing options...
ogre Posted May 11, 2010 Report Share Posted May 11, 2010 and it protects the noodle, i've bent the bit that makes the vee a quick release with my ankle enough times my shitty booster doesn't help with stiffness all that much (but i've got a built in booster..) but it's worth it for the protection. Quote Link to comment Share on other sites More sharing options...
