Themistoklidis Posted May 9, 2010 Report Share Posted May 9, 2010 Hey guys i need opinions on changing Vees to HS33 brakes.Im carently running Vees and im thinking of improving grip by switching to HS33 brakes. Quote Link to comment Share on other sites More sharing options...
philgresty Posted May 9, 2010 Report Share Posted May 9, 2010 in my opinion if i wer you id get sum good cnc v pads, possibly new arms if yours arent too good, sum sd7 avids are spot on, vees for the win, the evo adaptors for maggys tend to be abit gash Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 9, 2010 Report Share Posted May 9, 2010 If its on the 24" the vee will be a wise choice, great hold, good modulation (dependant on set up, not as bitey as a magura, but then that's not necessarily a bad thing on a 24" i use a rear vee and i love it. SD7 arms, decent linear slic cable, avid levers and you're sorted. Personally i run Plazmatic CRV pads, but pads are dependant on you set up and braking preference. Quote Link to comment Share on other sites More sharing options...
