Evo Adaptor
trials owns
hi there i have just fitted my mates evo adaptor and set it up but when i push the brake leaver in hard the right brake cylinder pops out of the mount when it is fully tight, why is this? i have set both sides out the same so it goes like this, the under booster then mount,brake cylinder, top mount, top booster, washer and then screw on the top and on the bottom its mounts and a screw clamping. i tried it with the quick release on one side but i think it done the same. can u help?
cheers
sod off the quick release, and just use another bolt that will push down on it ( like a shoulderbolt)
done that and is on the bike like that. but is not working for one side but it is working for the other side.......strange
Pictures?
camera flat at the mo
