jordan allsop Posted May 9, 2010 Report Share Posted May 9, 2010 right i have a monty 220 kamel and i want to run a bash plate and also a bash ring but everytime i try to set up the bike there always seems to be a problem with the chain rubbing on the frame so i have decided o cut off the bash plate mounts and just run a bash ring can somebody please tell me the best places to cut it and the neatest way that will keep it strong, thanks 1 Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted May 9, 2010 Report Share Posted May 9, 2010 why dont you just take the bash plate off and then leave it? if you cut the mounts off, it could possible look worse then the mounts. and plus you could mess it up Quote Link to comment Share on other sites More sharing options...
jordan allsop Posted May 9, 2010 Author Report Share Posted May 9, 2010 no because the chain actually rubs on the mounts :/ and im definetly going to cut them off just need to know the best way to do it and also where to do it cheers Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted May 9, 2010 Report Share Posted May 9, 2010 thats crazy lmao! what is the length of you bb?? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted May 9, 2010 Report Share Posted May 9, 2010 (edited) thats crazy lmao! what is the length of you bb?? How badly is it rubbing? If it's not too bad it'll sort itself out soon enough. Also what length bb? is that causing it? Edit: missed above comment Edited May 9, 2010 by Matt Vandart Quote Link to comment Share on other sites More sharing options...
joea Posted May 9, 2010 Report Share Posted May 9, 2010 you would be better off getting a a longer bb ten it will not Rube on the frame if that dose not work file off the frame Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted May 9, 2010 Report Share Posted May 9, 2010 If you are going to cut it off, grind it off with an angle grinder, just take your time about it, and i probaly wouldnt try and take it all off, just a leave a tiny bit of it, that way you no you arnt going to grind any of the frame Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted May 9, 2010 Report Share Posted May 9, 2010 Get a wider BB, if the chain is rubbing the chances are you're using the wrong size either that or the bashring you're using is about a mile too thick and pushing your chain line too close to your frame. Quote Link to comment Share on other sites More sharing options...
jordan allsop Posted May 10, 2010 Author Report Share Posted May 10, 2010 My bb length 128mm with 68mm shellThanks Quote Link to comment Share on other sites More sharing options...
