Inserting Headset Cups
Ashley Sayers
  On 5/2/2010 at 7:57 PM, rab shropshire said:
with a rubber mallet or a hammer and a block of wood
As a very last resort.
Do a search, it's been covered loads of times.
A long threaded rod with some big, thick washers and two nuts is all you need, DIY headset press win.
Take your time and don't keep pushing them if they're going in wonky
Edited by PeanuckleJive
  On 5/2/2010 at 8:32 PM, samtrialsbmx said:
good boy :D just like hit it to start it off... then hit it in different places till its at the bottom
place the cups gently in the frame, then put the whole headtuve with the cups in a vice and tighten it up untill its fitted, best and safest way to do it (Y)
