Arran Posted April 30, 2010 Report Share Posted April 30, 2010 Hey guys , Does grinding your rims help your brake ( Magura HS33 with brakets) grip onto the rim and not slip? Quote Link to comment Share on other sites More sharing options...
Riley1 Posted April 30, 2010 Report Share Posted April 30, 2010 It sure does, just make sure you dont grind through the rim Quote Link to comment Share on other sites More sharing options...
Arran Posted April 30, 2010 Author Report Share Posted April 30, 2010 cool thanks for reply . Quote Link to comment Share on other sites More sharing options...
^Mole^ Posted April 30, 2010 Report Share Posted April 30, 2010 Yup helps alot Quote Link to comment Share on other sites More sharing options...
hugo bashall Posted May 1, 2010 Report Share Posted May 1, 2010 Yeah helps a lot, especially if you do a deep grind. Check out Rim Grinding Will walk you through best ways to do it. Also what pads are you running? Hugo... Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted May 1, 2010 Report Share Posted May 1, 2010 Get a nice filthy grind, Filthier than the average whore, really does help your brakes grip and HONK! angle grinder with a cut off disc held at a steep angle to the rim works wonders for making a nice rough grind Quote Link to comment Share on other sites More sharing options...
Arran Posted May 1, 2010 Author Report Share Posted May 1, 2010 ive got the normal pads hich come with the hs33 from tartybikes Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted May 1, 2010 Report Share Posted May 1, 2010 ive got the normal pads hich come with the hs33 from tartybikes get decent pads too, magura blacks are toss! if you have a few quid to spend, heatsink yellows have a really good rep, same with the cousts. the cnc backings make a big difference Quote Link to comment Share on other sites More sharing options...
monty-james Posted May 1, 2010 Report Share Posted May 1, 2010 Yeah, grinds do help alot, i would say have a MEGA deep grind because, well use some common sense, it cant be too good for the rim. An average grind is just right really, although if you cant be bothered to do a grind on your rim; just use some tar, its really good in the summer. The only bad parts about tar is the amount of times you have to put it on and that it runs in rain, making your brakes slippy. Sorry about the slight wall of text Quote Link to comment Share on other sites More sharing options...
valy_kara Posted May 1, 2010 Report Share Posted May 1, 2010 if you grind the rim , with the black magura pads , max one day to gett to the plastic of them Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted May 1, 2010 Report Share Posted May 1, 2010 if you grind the rim , with the black magura pads , max one day to gett to the plastic of them I had a grind with black pads and they lasted far longer than a softer pad like my new heatsink reds. Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted May 1, 2010 Report Share Posted May 1, 2010 If your brake isnt slipping without a grind at the minit then i wouldnt bother putting one on. I would look at information about your pads and see what the best suggested use for them is then do that, it will probally require a grind. Quote Link to comment Share on other sites More sharing options...
Borat Posted May 1, 2010 Report Share Posted May 1, 2010 Dude, get yourself some Tnn LGM's and a grind. The best brake setup you will ever use. http://tartybikes.co.uk/product.php?product_id=10892&category_id=4 Quote Link to comment Share on other sites More sharing options...
