J Trials 31 Posted April 29, 2010 Report Share Posted April 29, 2010 Alright got some Meta isis cranks that I need to pull off my Zhi, so what tool will I need. I only have a sq. taper crank puller so obviously that won't work. Quote Link to comment Share on other sites More sharing options...
Nick Melson Posted April 29, 2010 Report Share Posted April 29, 2010 Alright got some Meta isis cranks that I need to pull off my Zhi, so what tool will I need. I only have a sq. taper crank puller so obviously that won't work. Put a penny in the crank hole then put the puller on use to work a few years ago with me.... Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted April 30, 2010 Author Report Share Posted April 30, 2010 Put a penny in the crank hole then put the puller on use to work a few years ago with me.... Pennys are different over here, anyway I got it off. I ground off a bolt and stuck it in there then used the crank puller. Quote Link to comment Share on other sites More sharing options...
Muel Posted April 30, 2010 Report Share Posted April 30, 2010 The bolt method is better, coins can easily be crushed and pushed inside the bb. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 30, 2010 Report Share Posted April 30, 2010 The bolt method is better, coins can easily be crushed and pushed inside the bb. But when it goes right, you get one badass 5p coin! I had to remove my crank on a ride last week, the coin method worked perfect but yes, the bolt method Is better for that reason Quote Link to comment Share on other sites More sharing options...
