My Crank Is Broke
Is it still possible to get the bottom bracket out when you glue it on?
When its glued on you probably cant get it off without some big force, but what "ashes" might of ment was the blue loctite stuff which "Locks threaded fasteners against vibration loosening" so you basically can only get the crank off if you want to take it off.
blue loctite
Is this the same stuff?
My link
I think ill go for this. I have the same problem. It comes from the spline on the crank
wearing from being ridden a little loose. I learned the hard way <_< (as usual)
Edited by Theo
My link
yeah it is the same stuff :)
just get a new bb/cranks then put loctite on, tighten the bolt up and you should be fine because ive never had to tighten mine up :)
  • Like 1
I've got the same bike and have just shelled out on new ISIS bb & cranks.
Does it still creak immediately after you've tightened it? If so you probably need new cranks at least. Otherwise, hopefully Loctite will do the trick.
I've never ridden for long with loose cranks, used Loctite and for the last few weeks have been bringing an 8mm allen key for all my rides.
The creaking has been getting worse despite me running them tighter and tighter.
Square taper combined with soft crank alloy isn't a good combo, ISIS ***. If you are going to get new cranks, 7075 t6 alloy is what you ideally want as it's a lot stronger than 6061
blue loctite
Thats what i meant ..... sorry about not making it that clear. :$
i had the same probaly dude. on my old blade the crank had come loose and i ignored it then it worn. this happened a cuple of tiime because im a noob . once you get new cranks ( if you do ) id give them a tighten every time you ride your bike and tighten the pedals aswell, i do it. may be a lil but anoying but its worth it ..
hope this helps
matt
hope this helps
matt
This aint bullshit. Seriously check your cranks and pedals for tightness before every ride. Just do it. Please!
I learned this the hard way. F*cked up my cranks.
