tomsutton Posted April 23, 2010 Report Share Posted April 23, 2010 I have a chain splitter need to get rear wheel off to put a new tyre on. Im finding it really hard to split my chain. The pins refused to come out. Im not sure which link to use there is a link which is plated black. Any help would be appreciated Thanks Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted April 23, 2010 Report Share Posted April 23, 2010 OFF TOPIC : Ride sunday ?? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted April 23, 2010 Report Share Posted April 23, 2010 You don't need to split your chain to get the wheel out. Quote Link to comment Share on other sites More sharing options...
tomsutton Posted April 23, 2010 Author Report Share Posted April 23, 2010 (edited) You don't need to split your chain to get the wheel out. If you could explain how i do it would be much appreciated. Cheers Edited April 23, 2010 by tomsutton Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted April 23, 2010 Report Share Posted April 23, 2010 Undo your chain tensioners, push your wheel all the way forward into the dropouts then push/lift the chain off to the side on the front sprocket while pedalling slowly. Quote Link to comment Share on other sites More sharing options...
tomsutton Posted April 23, 2010 Author Report Share Posted April 23, 2010 My bike is mod with freewheel at the front, the chain is to tight for it to come off? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted April 23, 2010 Report Share Posted April 23, 2010 As I said, undo your chain tensioners and push the wheel forward. It'll loosen off the chain. Quote Link to comment Share on other sites More sharing options...
waduc Posted April 23, 2010 Report Share Posted April 23, 2010 (edited) As I said, undo your chain tensioners and push the wheel forward. It'll loosen off the chain. after you undo the chain tensioners the chain should be loose,therefore you can push the wheel forwards and take the wheel off. hope it helps,GL Edited April 23, 2010 by waduc Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted April 23, 2010 Report Share Posted April 23, 2010 Unless the chain is at a stupid short length:P Quote Link to comment Share on other sites More sharing options...
Borat Posted April 23, 2010 Report Share Posted April 23, 2010 Take the crank off? May ruin the taper or splines if you keep doing it. But if your chain is a stupid lenth, it's your best bet! Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted April 23, 2010 Report Share Posted April 23, 2010 should be able to get the chain of with the tool, if there is a clip on the chain then just undo that it's easy. Or if its the other type of chain the should be a pin it looks slightly different to the other links, it only goes out one way so you the tool on it the wright way. Quote Link to comment Share on other sites More sharing options...
tomsutton Posted April 23, 2010 Author Report Share Posted April 23, 2010 Cheers for all the replies got it sorted. For some reason now the pads rub against the rims, even though i havent touched any of brakes etc? Quote Link to comment Share on other sites More sharing options...
waduc Posted April 23, 2010 Report Share Posted April 23, 2010 (edited) Cheers for all the replies got it sorted. For some reason now the pads rub against the rims, even though i havent touched any of brakes etc? center the wheel/adjust the pads... and don't forget to adjust the chain tensioner Edited April 23, 2010 by waduc Quote Link to comment Share on other sites More sharing options...
