Crankarm Too Close To The Frame
ryac
Hi all,
Had a bike custom-built three months ago, however the crankarms seem to be too close to the frame. Check out the scratches:
The first attempt was to put spacers in to widen it out and that seemed to help but still not quite enough. I dont know if it's possible to put more spacers in or if there are other/better methods to go about fixing this? The bike shop mentioned that they'll grind the crankarms but doesnt sound like a proper way to fix this problem. Is this a common problem?
Thanks for your feedback..
i had this problem with my mod.
dont buy a wider bb cause it will offset your chain line.
buy new crank arms with a bigger offset.
this is what i did as my old tryall cranks had something like a 26mm offset, and i couldnt ride them with my new frame cause they hit it and the brake... so i just baught new zoo crank arms which had a 36mm offset and now everything is perfect :D
  • Like 1
If it's just rubbing on one side, you could try a thin BB spacer between your drive-side cup and the frame? The same one you get to reduce a 73mm BB to a 68mm. That's assuming that isn't the sort of spacer you've used already. Other than that, a bit of grinding might help.
thanks for that.
the right crank was ground in the end. it's rare that it will scratch now but still can happen. I do think it's better to get a wider BB or cranks with a bigger offset though.
