pizzapie.. Posted April 22, 2010 Report Share Posted April 22, 2010 Just wondering it is the same as a normal magura? So can you bath bleed them? thanks lil liam Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted April 22, 2010 Report Share Posted April 22, 2010 Just wondering it is the same as a normal magura? So can you bath bleed them? thanks lil liam do you mean like submearge them in water and bleed it with water? if thats the case then, i wouldn't. They have leeking problems with oil, let alone with water. if you really want a water bleed then stick to the hs33. Quote Link to comment Share on other sites More sharing options...
BlueSmokeyJoe Posted April 22, 2010 Report Share Posted April 22, 2010 (edited) Yes, BUT, bleeding them with with water will not only void the warranty but also make it prone to leaking. Stick with the standard oil bleed, if it aint broke....... Edited April 22, 2010 by BlueSmokeyJoe Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted April 22, 2010 Report Share Posted April 22, 2010 Just do it. Don't think any of the newer denguras have had any problems, it's just the old ones give them all a bad name. My guess is those 2 ^^ haven't even used the brake and are just slating it based on what they've read on here... You can bath bleed them and they are fine. Mine was. As was my mates... Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted April 22, 2010 Report Share Posted April 22, 2010 (edited) Just do it. Don't think any of the newer denguras have had any problems, it's just the old ones give them all a bad name. My guess is those 2 ^^ haven't even used the brake and are just slating it based on what they've read on here... You can bath bleed them and they are fine. Mine was. As was my mates... some of my mates used one.. water bled it, and it was crap! they leaked like a bitch and the feel of it was crap also. so i have had a bit of experiance with them Edited April 22, 2010 by samtrialsbmx Quote Link to comment Share on other sites More sharing options...
BlueSmokeyJoe Posted April 22, 2010 Report Share Posted April 22, 2010 Yes, BUT, bleeding them with with water will not only void the warranty but also make it prone to leaking. Stick with the standard oil bleed, if it aint broke....... Just do it. Don't think any of the newer denguras have had any problems, it's just the old ones give them all a bad name. My guess is those 2 ^^ haven't even used the brake and are just slating it based on what they've read on here... You can bath bleed them and they are fine. Mine was. As was my mates... True, I have never used the Dengura but I wasn't slating it. Purely pointing out that they are not recommended for use with water bleeds. I never said it would leak, just that there was an increased risk. Is it really worth rebleeding the brake if its working fine? Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted April 22, 2010 Report Share Posted April 22, 2010 not being funny but why cant you just bleed normaly with oil ! Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted April 22, 2010 Report Share Posted April 22, 2010 not being funny but why cant you just bleed normaly with oil ! feels shit and isnt free Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted April 23, 2010 Report Share Posted April 23, 2010 I dont understand where you people get your information from. Mark has tried and tested these brakes and explained that if they're cleaned out when you first get them then you'll have absolutly no problems with them. Quote Link to comment Share on other sites More sharing options...
Jason222 Posted April 23, 2010 Report Share Posted April 23, 2010 Deng brakes are shit. The first ones are shit, and the new SL ones are shit too. Bleed them with water and they're even worse. Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted April 23, 2010 Report Share Posted April 23, 2010 Deng brakes are shit. The first ones are shit, and the new SL ones are shit too. Bleed them with water and they're even worse. +1 Quote Link to comment Share on other sites More sharing options...
stunt man t Posted April 23, 2010 Report Share Posted April 23, 2010 (edited) Deng brakes are shit. The first ones are shit, and the new SL ones are shit too. Bleed them with water and they're even worse. my TR ones are fine bled with oil i wouldnt bother trying with water as there not designed to be Edited April 23, 2010 by stunt man t Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted April 23, 2010 Report Share Posted April 23, 2010 Nor are Maguras but that hasn't stopped people, nor has it stopped it from being a viable alternative. I can't see the point in the extra money for Deng brakes? Quote Link to comment Share on other sites More sharing options...
mods Posted April 23, 2010 Report Share Posted April 23, 2010 Nor are Maguras but that hasn't stopped people, nor has it stopped it from being a viable alternative. I can't see the point in the extra money for Deng brakes? how much is oil? lol Are people really that tight. I dont think you should have a hobby if you cant afford to fund it. That said a water bleed does work ok in a hs33. I always bled mine with oil and my brake was amazing. Felt just as good if not better than any others i tried. My advise, bleed it with oil. Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted April 23, 2010 Report Share Posted April 23, 2010 how much is oil? lol Are people really that tight. I dont think you should have a hobby if you cant afford to fund it. That said a water bleed does work ok in a hs33. I always bled mine with oil and my brake was amazing. Felt just as good if not better than any others i tried. My advise, bleed it with oil. How can it possibly feel better when water is thinner Quote Link to comment Share on other sites More sharing options...
mods Posted April 23, 2010 Report Share Posted April 23, 2010 personal preferance. I got on well with oil..You get on well with water.. happy days. Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted April 24, 2010 Report Share Posted April 24, 2010 water does feel good, but i think oil still feels good to. the only reason i have a water bleed at the moment is because i didnt have enough fluid to refill the system after i changed the cylinders lol. but either way it still works great Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted April 24, 2010 Report Share Posted April 24, 2010 Try water in it, if its its shit then go back to oil it doesnt take long to bleed a brake. Quote Link to comment Share on other sites More sharing options...
