koxxboy14 Posted April 22, 2010 Report Share Posted April 22, 2010 Hi I've just got my new monty. It came disassembled and the front wheel was off. I can't fit it becuase the disk brake on it dosen't fit in between the pads. How do I expand the pads and make it fit? Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted April 22, 2010 Report Share Posted April 22, 2010 What disk brake is it? Quote Link to comment Share on other sites More sharing options...
Skoze Posted April 22, 2010 Report Share Posted April 22, 2010 I'll bet you/ someone squeezed the lever? Take the pads out, ease the pistons back with a flat headed screwdriver. Should be fine, if anything starts leaking fluid you've f**ked it. My first Hope did that, split the diaphragm in the lever when i accidentally pumped the brake with no rotor in. Quote Link to comment Share on other sites More sharing options...
