Hungry Chain
stunt man t
can anyone help?
ive noticed that my chain is rubing on my frame, and its prety deep :(
its a onza blade frame, rockman bub hub and trial-tech sprocket
im kinda worried as its a new frame, that itll get that deep that itll snap
does any body have a suggestion on how i can solve it?
some one told me to turn the sprocket round, but ive tried it and then the chain hits the spoke heads :S
please help :(
Smaller axle'd BB, Thinner chain ?. It's happening on my Limey aswel, i'm going to wrap a little bit of tape which you put on tennis rackets just too reduced wear.
smaller axle bb wont let my free wheel turn :(
its a trial-tech lite chain, can u get a smaller one which is ok for trials?
i need some of that tape :P
Swapping to a 3/32" chain like the Lite or K810 will save you a couple of mm, which might be enough to make a difference. Other than that, a shorter BB, spacer behind your freewheel (if you've got room), or getting a TR sprocket (which has the teeth centrally mounted rather than offset). It sucks that they pretty much all involve money, but that's bikes I guess...
EDIT: Simultaneous post = fail :P
Spacer or TR sprocket may be the way.
the chain is a Trialtech Lite Z610 HX, 3/32'' :(
might be able to fit a bit shorter then a 128mm bb but its not much room as i use a bash ring
TR or try-all sprocket then i guess?
what freewheel you running? if it's one of them ones with the claw type protusions on the back which the freewheel tool slots into, getting a shorter BB and a freewheel which has the tool grooves recessed into the body should give you some extra space too
try-all 108.9?
didnt quiet get the rest :giggle:
What gearing are you using? Could be the size of the sprocket...
18T freewheel
12T sprocket
:D
Im poor, so I used an old innertube, cut it up, and taped it round the frame where the chain was hitting. :-
did that work?
wouldnt the chain just cut through the soft rubber inner tube and still cut the frame
as the chain is in the same place?
edit: isnt youres a full onza build (looks like it in your pic) so it sholudnt rub? :S
Edited by stunt man t
did that work?
Seems to work for me only had it on a few weeks though, it may well need replacing if I never get a new chain, but there's only a few marks on the rubber so far (Y)
I think it would be a good id to listen to the pros here though :P
edit: I need a new chain, thats why it's rubbing at the moment. Should be one on it's way hopefully though!
Edited by Theo
Seems to work for me only had it on a few weeks though, it may well need replacing later but there's only a few marks on the rubber so far (Y)
I think it would be a good id to listen to the pro's here though :P
yeah i no mate
just means i wont be able to ride till monday :(
do you think itll b ok til then to use?
its only 5 days old :P
i cant even get the sprocket off anyway :( its solid and cant find a tool to get from tarty
another topic starter ;)
I had this problem, just flip your 12t sprocket over should be fine, just watch it does rub on your spokes instead.
it does :(
ill order a tr sprocket on friday aswell as some more bits (Y)
thanks for youre help guys :wub:
Yep: http://tartybikes.co.uk/media.php?group=guides&id=1 - 1:30 Mins onwards.
As said, a TR sprocket will probably do the job, or flipping your Trialtech one and sticking a slim spacer in.
thanks adam ;)
