Cahill Trials Kid Posted April 18, 2010 Report Share Posted April 18, 2010 Rite think im going to go to a rear maggie, but would like to get some of the braided hose as i ride competitions alot and dont want it leaking in a comp. I no that most people bleed maguras with water but if you use braided hose will it rust it ?? Cheers Sam Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 18, 2010 Report Share Posted April 18, 2010 Rite think im going to go to a rear maggie, but would like to get some of the braided hose as i ride competitions alot and dont want it leaking in a comp. I no that most people bleed maguras with water but if you use braided hose will it rust it ?? Cheers Sam it wont rust it because there is a plastic tube inside the stainless steel braid Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 18, 2010 Report Share Posted April 18, 2010 I've got water bled braided hose, feels good do it! Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted April 18, 2010 Author Report Share Posted April 18, 2010 Thanks for the replies guys anyone else agree with theses ?? Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted April 18, 2010 Report Share Posted April 18, 2010 Thanks for the replies guys anyone else agree with theses ?? Yeah, I ran braided for ages on a water bleed was fine.. Quote Link to comment Share on other sites More sharing options...
martin555 Posted April 18, 2010 Report Share Posted April 18, 2010 Does braided hose make the brake feel more powerfull? due to the pipe not being able to expand at all? Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted April 18, 2010 Author Report Share Posted April 18, 2010 Does braided hose make the brake feel more powerfull? due to the pipe not being able to expand at all? It wont make much difference with its performance but it wont split if u kick it or knock it on a rock/wall Quote Link to comment Share on other sites More sharing options...
martin555 Posted April 18, 2010 Report Share Posted April 18, 2010 (edited) It wont make much difference with its performance but it wont split if u kick it or knock it on a rock/wall I knew about the obvious benefits. I just wondered as I was led to believe with motor bikes it makes quite a big difference but I guess motor bike brakes are a lot more powerful any way. Wondered if it was the same for push bikes but from what you say I guess it not. Edited April 18, 2010 by martin555 Quote Link to comment Share on other sites More sharing options...
davey1991 Posted April 18, 2010 Report Share Posted April 18, 2010 I knew about the obvious benefits. I just wondered as I was led to believe with motor bikes it makes quite a big difference but I guess motor bike brakes are a lot more powerful any way. Wondered if it was the same for push bikes but from what you say I guess it not. Technically it is true but the change is so small you probably wont notice it. Any affect you do feel will probably only be placeabo. Quote Link to comment Share on other sites More sharing options...
Riley1 Posted April 19, 2010 Report Share Posted April 19, 2010 Slightly off topic but can someone please explain the difference in breaking performance with Oil vs Water blead? Cheers Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 19, 2010 Report Share Posted April 19, 2010 Slightly off topic but can someone please explain the difference in breaking performance with Oil vs Water blead? None at all. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted April 19, 2010 Report Share Posted April 19, 2010 None at all. Just a more responsive feel. Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted April 19, 2010 Report Share Posted April 19, 2010 Slightly off topic but can someone please explain the difference in breaking performance with Oil vs Water blead? Cheers Depends on the oil, anyway usually oil has more spongy feel. Quote Link to comment Share on other sites More sharing options...
0zzy Posted April 19, 2010 Report Share Posted April 19, 2010 supposibly using a braided hosing makes the brake feel stiffer, i use the hope kevlar stuff on tarty, it seems tough and still light Quote Link to comment Share on other sites More sharing options...
