Echo Tr Snail Cams.
nickdonboy
Noob question.. Will Echo TR snailys fit a chirs king bmx hub?
http://www.tartybike...category_id=114
No. When I had one , I used a try-all smooth ones that I drilled out. If you cannot put them outside the frame, recommend only using one, like I did too, but watch for the other side, my single speed king was eating the drop out a bit and deforming it.
