monty-adam Posted April 18, 2010 Report Share Posted April 18, 2010 (edited) Hello all, sorted now please close Thankyou Edited April 18, 2010 by monty-adam Quote Link to comment Share on other sites More sharing options...
Bucky Posted April 18, 2010 Report Share Posted April 18, 2010 Hello all, I recently bought a new amp for my system but unfortunatley when i was wiring it in last night in a rush before it got dark whilst talking to my gf , i switched the 12v and the ground by accident!! I realised because the fuse had blown for that amp in my distribution block, swapped the wires around and put a new fuse in, the amp started up fine, not in protection mode to my surprise, and all seemed fine. Untill i connected my sub up, it works, however even when the volume is on zero there is a buzzing coming from the sub, iv tried different earth points on bare metal frame, iv tried a different RCA from the head unit straight to the amp to eliminate interference, is the amp just F**ked or could it be something else?? Thankyou are you running your RCA's, and power lead near each other? i had an issue with buzz when they were next to each other in the centre console, i moved one to the kick panel and is seemed to cure it . Quote Link to comment Share on other sites More sharing options...
monty-adam Posted April 18, 2010 Author Report Share Posted April 18, 2010 Well its the amp , i eliminated everything else one by one and pluged another amp in and it was fine, please close this topic. Quote Link to comment Share on other sites More sharing options...
