tdubz Posted April 17, 2010 Report Share Posted April 17, 2010 Just Bought a hope hub off ebay for my xc bike couple of problems the axle is too wide for my frame!!!!! also the axle does not appear to be very tight in the hub and you can quite easily pull the hub to pieces how do i solve these problems thanks thomas Quote Link to comment Share on other sites More sharing options...
Danny Posted April 17, 2010 Report Share Posted April 17, 2010 What hub is it? Pics? Quote Link to comment Share on other sites More sharing options...
tdubz Posted April 17, 2010 Author Report Share Posted April 17, 2010 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250606948108&ssPageName=STRK:MEWNX:IT that is the link to the winning page Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 17, 2010 Report Share Posted April 17, 2010 The problem with the axle being loose is it's meant to come out. The problem with the axle being too big is it's 12mm The problem is, you bought a hub designed for a downhill bike. Stick with what you know. You now have to sell this hub on... Quote Link to comment Share on other sites More sharing options...
Danny Posted April 17, 2010 Report Share Posted April 17, 2010 You need an axle conversion kit as said above you've bought a 12mm bolt through axle hub. Theres a kit similar to this http://www.chainreactioncycles.com/Models.aspx?ModelID=5274 but for the hope xc. CRC don't seem to stock it any more but you should be able to get one somewhere. Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted April 17, 2010 Report Share Posted April 17, 2010 As hes bought a Bulb, that is actually the kit he needs. But personally I'd sell the hub on and buy the right one instead, will probably work out cheaper Quote Link to comment Share on other sites More sharing options...
Danny Posted April 17, 2010 Report Share Posted April 17, 2010 Oh it could be a bulb actually matt as you say They just had a slightly fatter shell and more engagements right? Quote Link to comment Share on other sites More sharing options...
tdubz Posted April 17, 2010 Author Report Share Posted April 17, 2010 (edited) will that do the trick? http://www.chainreactioncycles.com/Models.aspx?ModelID=18762 Edited April 17, 2010 by tdubz Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 17, 2010 Report Share Posted April 17, 2010 It will if it's a pro II and not a bulb or XC... Quote Link to comment Share on other sites More sharing options...
tdubz Posted April 17, 2010 Author Report Share Posted April 17, 2010 sorry i pasted the wrong link how about this one http://www.chainreactioncycles.com/Models.aspx?ModelID=5274 Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 17, 2010 Report Share Posted April 17, 2010 It's exactly the same as the link Danny posted. Quote Link to comment Share on other sites More sharing options...
tdubz Posted April 17, 2010 Author Report Share Posted April 17, 2010 It's exactly the same as the link Danny posted. ah that could be the winner then, might send hope an email just to confirm though thanks for your help lads Quote Link to comment Share on other sites More sharing options...
