staryarm69 Posted April 17, 2010 Report Share Posted April 17, 2010 Just trying to find out if any one is using the Monty Hose Splitter and does it carry any benefits as iv had I look at them on tarty and it says you'd be suppressed at how well splitters work. But id like to know if any one can give me some hands on advice from people who have used them as im currently building a gu typhoon n wont it to be a good mod bike. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 17, 2010 Report Share Posted April 17, 2010 I don't think there has ever been a totally agreed upon decision made about splitters, Some people say they make a world of difference, some people say they don't. Then people come along quoting physics stuff and try to prove each other wrong Quote Link to comment Share on other sites More sharing options...
Muel Posted April 17, 2010 Report Share Posted April 17, 2010 In terms of physics it makes no difference, it's a fluid filled system, therefore the pressure you put in at the lever is still split between the slaves. The splitters do make life better though, I use mine with two M8/M6 slaves, with the M6s blanked so you have each line that comes from the splitter going into a shroud nut and olive, this makes it far harder to kick either of the lines off when you're riding. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 17, 2010 Report Share Posted April 17, 2010 In terms of physics it makes no difference, it's a fluid filled system, therefore the pressure you put in at the lever is still split between the slaves. told you they'd come! That's the way I see it too though, makes sense I've finally got a frame now where I stand a chance of kicking my crossover off, so if I manage to, I'll probably try a splitter Quote Link to comment Share on other sites More sharing options...
staryarm69 Posted April 17, 2010 Author Report Share Posted April 17, 2010 In terms of physics it makes no difference, it's a fluid filled system, therefore the pressure you put in at the lever is still split between the slaves. The splitters do make life better though, I use mine with two M8/M6 slaves, with the M6s blanked so you have each line that comes from the splitter going into a shroud nut and olive, this makes it far harder to kick either of the lines off when you're riding. ok thanks but this might sound dumb but wots the m6/m8? im still pretty new to all this. told you they'd come! That's the way I see it too though, makes sense I've finally got a frame now where I stand a chance of kicking my crossover off, so if I manage to, I'll probably try a splitter you lol im just wontin to get my bike right out the box if u get me i wont everything to work n work good from the get go. carnt weit till its done n i can start ridin it. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 17, 2010 Report Share Posted April 17, 2010 ok thanks but this might sound dumb but wots the m6/m8? im still pretty new to all this. the thread size of the fittings on the brake hose if you go for the splitter option, you'll have to make an extra hose up and get an extra bleed screw to plug the slave cylinder, get M8 fittings for the hose and use the bigger holes on the cylinder body you lol im just wontin to get my bike right out the box if u get me i wont everything to work n work good from the get go. carnt weit till its done n i can start ridin it. Good that you're spending time building it right, A well built and maintained bike is far nicer to ride than one you slapped together quickly because because you were eager to ride, it'll also perform better and be less likely to fail Quote Link to comment Share on other sites More sharing options...
staryarm69 Posted April 17, 2010 Author Report Share Posted April 17, 2010 the thread size of the fittings on the brake hose if you go for the splitter option, you'll have to make an extra hose up and get an extra bleed screw to plug the slave cylinder, get M8 fittings for the hose and use the bigger holes on the cylinder body Good that you're spending time building it right, A well built and maintained bike is far nicer to ride than one you slapped together quickly because because you were eager to ride, it'll also perform better and be less likely to fail thanks i thort it was some thing to do with the theads. you im tackin my time iv got most of the main parts frame fork crank bars stem n a few other bits. i like to build my bikes properly am currently ridin bmx but carnt weit to get the mod out lol n iv found a local rider to show me the ropes to. Quote Link to comment Share on other sites More sharing options...
JT! Posted April 17, 2010 Report Share Posted April 17, 2010 IF you've just bought a brand new bike, then no don't bother. By all means change the pads (if the magura comes with standard magura pads) look into grinding your rim or using tar befor thinking about buying a splitter. Splitters only make the pads pull together more evenly, increasing bite, they don't make the brake hold better or make it more powerful. They do make your brake harder to bleed though. Quote Link to comment Share on other sites More sharing options...
staryarm69 Posted April 17, 2010 Author Report Share Posted April 17, 2010 IF you've just bought a brand new bike, then no don't bother. By all means change the pads (if the magura comes with standard magura pads) look into grinding your rim or using tar befor thinking about buying a splitter. Splitters only make the pads pull together more evenly, increasing bite, they don't make the brake hold better or make it more powerful. They do make your brake harder to bleed though. im mainley thinkin bout usin one to avoid broken hoses not got my brakes yet gonna ask for advice between the magura hs 33 and echo cnc rim brake on here sortly. Quote Link to comment Share on other sites More sharing options...
Borat Posted April 17, 2010 Report Share Posted April 17, 2010 In my honest opinion, they arent worth the fuss! Bleeding is effort, I have snapped a shit load of cables because of it! A nice braided hope crossover is exactly what you want! Quote Link to comment Share on other sites More sharing options...
staryarm69 Posted April 17, 2010 Author Report Share Posted April 17, 2010 In my honest opinion, they arent worth the fuss! Bleeding is effort, I have snapped a shit load of cables because of it! A nice braided hope crossover is exactly what you want! iv got a sort bit of braided hose from my dh bike it will make two crossovers easy u think that wud be the better why ? Quote Link to comment Share on other sites More sharing options...
Juan Manuel Posted July 18, 2010 Report Share Posted July 18, 2010 iv got a sort bit of braided hose from my dh bike it will make two crossovers easy u think that wud be the better why ? Because you wont snap it and it'll still be easier to bleed than using a splitter... If you don't have much experience bleeding a brake i wouldn't use a splitter. Quote Link to comment Share on other sites More sharing options...
