Magura Leaking..
Borat
Easy guys,
Basically, today, my magura has lost a shit load of fluid. Over a rapid period of time.
I have searched high and low, to come across nothing! I know without anyone else having a proper look, you cant really diagnose anything. But does anyone have any ideas of what it could be? As I am clueless to how to search more efficiently.. :/
bleed it again, and give it a slow squeeze and see if you can see where the fluid is coming out of? probably the best way to properly see where it's going wrong
Yep. Give the brake a good clean and dry first so its easier to spot any leaks. Make sure all the hose connections are tight enough as that can cause leaking.
