Arran Posted April 14, 2010 Report Share Posted April 14, 2010 Hi guys, need some help with how to install a Magura Brake ( HS33 ) any kind of responce would be useful ( videos, pictures). The manual is really unhelpful it's for an Onza Bird 09. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 14, 2010 Report Share Posted April 14, 2010 does it have V brake or 4 bolt magura mounts? Quote Link to comment Share on other sites More sharing options...
Arran Posted April 14, 2010 Author Report Share Posted April 14, 2010 It has an EVO2 rim mount with the hydrallic brakes. ( rear) Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted April 14, 2010 Report Share Posted April 14, 2010 Vee....in which case you'll be using the tiresome Evo mounting system. Fitting Guide Magura Service Manual (official fitting instructions ) Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted April 14, 2010 Report Share Posted April 14, 2010 well this will make it square for you and show you how to set it up. do it with both sides obviosly rim brake tutorial Quote Link to comment Share on other sites More sharing options...
Arran Posted April 15, 2010 Author Report Share Posted April 15, 2010 I've done the actual brakes, but I need help to assemble the mount ( EVO2 ) becuase the Magura setup manual is crud.!! Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted April 15, 2010 Report Share Posted April 15, 2010 I've done the actual brakes, but I need help to assemble the mount ( EVO2 ) becuase the Magura setup manual is crud.!! Well sorry not sure. Good luck anyways Quote Link to comment Share on other sites More sharing options...
