Juhoman Posted April 14, 2010 Report Share Posted April 14, 2010 Hi, I was wondering if i should spend some money on trials-tyres if i'm going to do some "from A to B riding" aswell as trials? Tyres i'm currently on are crappy worn out mtb tyres which are slippy as ice if wet. So if i ride tyres like TryAll Sticky will they be gone in like a month? If yes, what should i get to get optimal wear life with reasonable grip? Or should i put my money on something else and grind my old tyres to slics and go ghetto? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted April 14, 2010 Report Share Posted April 14, 2010 (edited) [ well if you ride really good and ride alot they will be gone in a month but something like onza sticky fingers. im riding them and ive been riding them since last august. try-all if your just starting, onza if your a full time rider. or whatever one you prefer. thats just what i think Edited April 14, 2010 by modifiedridah2k9 Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted April 14, 2010 Report Share Posted April 14, 2010 maxis, if your on a stock in my opinion. but i ride a mod so im not 100% sure Quote Link to comment Share on other sites More sharing options...
samster Posted April 14, 2010 Report Share Posted April 14, 2010 On 4/14/2010 at 5:03 PM, Juhoman said: Hi, I was wondering if i should spend some money on trials-tyres if i'm going to do some "from A to B riding" aswell as trials? Tyres i'm currently on are crappy worn out mtb tyres which are slippy as ice if wet. So if i ride tyres like TryAll Sticky will they be gone in like a month? If yes, what should i get to get optimal wear life with reasonable grip? Or should i put my money on something else and grind my old tyres to slics and go ghetto? It depends on what type of terrain your riding because: if your riding competions and you want maximum grip go for the softer compound tryalls. but if your riding street you'll want something grippy which will also last longer so go for the harder compound Maxxis tyres. Seen as your wanting A to B tyres you best option will probably maxxis . i cant really suggest any because i don't ride stock Quote Link to comment Share on other sites More sharing options...
Juhoman Posted April 14, 2010 Author Report Share Posted April 14, 2010 (edited) On 4/14/2010 at 6:01 PM, samster said: It depends on what type of terrain your riding because: if your riding competions and you want maximum grip go for the softer compound tryalls. but if your riding street you'll want something grippy which will also last longer so go for the harder compound Maxxis tyres. Seen as your wanting A to B tyres you best option will probably maxxis . i cant really suggest any because i don't ride stock I ride some streety stuff while i find a street from this wilderness i live in. Usually i ride on gravel with some pallets etc. Taking into consideration the terrain would the TryAll stickys provide better grip or should i just go for the maxxis. And if so which one(Minion, High Roller, Swampthing...)? oh, and the A to B stuff comes in when i go looking for the street to do street. Maybe one should learn to drive. Edited April 14, 2010 by Juhoman Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 14, 2010 Report Share Posted April 14, 2010 i have had a duel ply high roler on the rear for about a year now mate and its hardly showing any sign of wear, my set up is high roller on rear and try-all on front Quote Link to comment Share on other sites More sharing options...
Juhoman Posted April 14, 2010 Author Report Share Posted April 14, 2010 On 4/14/2010 at 6:46 PM, rab shropshire said: i have had a duel ply high roler on the rear for about a year now mate and its hardly showing any sign of wear, my set up is high roller on rear and try-all on front Super Tacky 42a compound i presume. Sounds promising. On gravel, grain size about half an inch would it be better to have big knobs or smaller ones? You could assume that big knobbed tyre would rip the ground more than slicker one. If those grains get rolling grip is lost. So would it make sense to pick up tyre like Minion ( http://www.tartybike...&category_id=33 ) or even Larsen 8 http://www.tartybike...&category_id=33 ) over let's say Hi Roller ( http://www.tartybike...&category_id=33 )? Smoother ones have lower price and they're lighter.. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 14, 2010 Report Share Posted April 14, 2010 yes mate 42a, I have used this combination of tyres on mud, gravel, wet grass, pretty much everything and it grips really well, and because they are not very expensive, when it does wear down they can be replaced easily, I really do love my rear tyre, never had a pinch flat. just make sure you get the dual ply as I have tried the single ply on the rear and it just folds under pressure.oh and i would recommend the 2.35 instead of the 2.50 Quote Link to comment Share on other sites More sharing options...
Juhoman Posted April 14, 2010 Author Report Share Posted April 14, 2010 On 4/14/2010 at 7:18 PM, rab shropshire said: oh and i would recommend the 2.35 instead of the 2.50 why? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 14, 2010 Report Share Posted April 14, 2010 the 2.35 seems to sit better on the rim and is more stable, this is probably just personal preference, but its also lighter. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted April 14, 2010 Report Share Posted April 14, 2010 On 4/14/2010 at 5:07 PM, modifiedridah2k9 said: [ well if you ride really good and ride alot they will be gone in a month but something like onza sticky fingers. im riding them and ive been riding them since last august. try-all if your just starting, onza if your a full time rider. or whatever one you prefer. thats just what i think Onza sticky fingers are horrid... The Try-all probably wear down the fastest so I'm not sure why they'd be good for a beginner? IF anything the "full time rider" should use Maxxis or Continental. On 4/14/2010 at 5:14 PM, samtrialsbmx said: maxis, if your on a stock in my opinion. but i ride a mod so im not 100% sure Maxxis are pretty good, but the continental are just that little bit superior in pretty much every way I've found On 4/14/2010 at 7:30 PM, Juhoman said: why? Lighter Quote Link to comment Share on other sites More sharing options...
Juhoman Posted April 14, 2010 Author Report Share Posted April 14, 2010 Thanks for replys! I think i have reached a conclusion concerning this issue. Going for maxxis as suggested. This probably saved me some money on the long run. Quote Link to comment Share on other sites More sharing options...
craigjames Posted April 14, 2010 Report Share Posted April 14, 2010 Find my Kenda folding 2.5 nevegal DTC better than the Conti Rubber Queen, more pinch prone that a dual ply maxxis, better than a Conti, much more bounce than a dual ply Maxxis and lighter too. Seems to wear really well too. Quote Link to comment Share on other sites More sharing options...
shamus Posted April 14, 2010 Report Share Posted April 14, 2010 If you're worried about wear life it'll be the compound which will dictate the life span of a tyre. I have a harder compound dual ply high roller rear tyre, had it for ages and it still looks in good shape. About 2 months after I bought the rear, I went for a super tacky single ply front tyre, that's pretty much nailed already. Awesome grip, just going place to place has beasted it. Quote Link to comment Share on other sites More sharing options...
Onza T-Comp boy Posted April 14, 2010 Report Share Posted April 14, 2010 i'd say monty or maxxis creepy crawler Quote Link to comment Share on other sites More sharing options...
