Mikey Tomo Posted April 14, 2010 Report Share Posted April 14, 2010 (edited) Ok I'm in desperate need of swapping bottom brackets over as soon as possible. I don't really have the money either for the proper tool so is there anyway you can take an SKF bottom bracket out without the Truvativ Bottom Bracket Tool? Edited April 14, 2010 by Mikey Tomo Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 14, 2010 Report Share Posted April 14, 2010 Yeah, a bit of WD40 and a screwdriver and hammer, and care. Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 14, 2010 Author Report Share Posted April 14, 2010 Yeah, a bit of WD40 and a screwdriver and hammer, and care. Was thinking that but it's going into another frame so don't want to be chiseling pieces off? Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 14, 2010 Report Share Posted April 14, 2010 Hence the care bit. Hot water on the BB shell can help, and also only using one slot so that the rest remain in good form means you stand more chance of using it if you ruin that one slot. Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 14, 2010 Author Report Share Posted April 14, 2010 Ahh never thought about the slot idea. Will give it ago in the morning cheers x. Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted April 14, 2010 Report Share Posted April 14, 2010 Another idea: Not sure if theres enough to grip, but maybe putting the side of the BB in a vice and using the frame as leverage? Just might not be enough meat on the BB to grip onto. Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 14, 2010 Author Report Share Posted April 14, 2010 Another idea: Not sure if theres enough to grip, but maybe putting the side of the BB in a vice and using the frame as leverage? Just might not be enough meat on the BB to grip onto. But if I did that wouldn't one side become extremely tight? Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted April 14, 2010 Report Share Posted April 14, 2010 But if I did that wouldn't one side become extremely tight? Shouldnt do, ive had to do it plenty of times because my brother is incapable of doing anything properly. Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted April 14, 2010 Report Share Posted April 14, 2010 I can see why it would either. Your only unscrewing the threads. Just make sure the vice you use has good jaws on it, for maximum grip. Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted April 14, 2010 Report Share Posted April 14, 2010 If it's anywhere near as tight as it should be, then you will damage it if you try to hammer it out. Mole grips might work if its well greased and not too tight, but again you will probably damage the cups. Is it not worth asking on here for any local riders with the tool? Or even going to your LBS and ask nicely, they might do it for a small fee. Got any friends that work at Halfords? It really is worth doing things properly sometimes. If you damage the cups too much then you will have to throw it away and buy a new BB, false economy at its finest. Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 14, 2010 Author Report Share Posted April 14, 2010 Went to LBS, didn't have the tool. Went to Halfrauds, didn't have the tool. Tried mole grips and vice and none worked. Finally resorted to the hammer and screwdriver which I was dreading, and I was right to... Half my bottom bracket cup is in my shed on the floor but bottom bracket is finally in so all is good Quote Link to comment Share on other sites More sharing options...
Filo Posted April 15, 2010 Report Share Posted April 15, 2010 really should get the tool if your gona take it out again,itll come loose when you ride Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 15, 2010 Report Share Posted April 15, 2010 does nobody you ride with have the tool and can let you use it for all of ten minutes? I switched frames earlier this week and my BB was a bitch to remove, I can't imagine having any luck removing it with a hammer and screwdriver Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 15, 2010 Author Report Share Posted April 15, 2010 Nope, one person had a tool but for SKF bottom brackets there is only the Truvativ one that fits. Quote Link to comment Share on other sites More sharing options...
Filo Posted April 15, 2010 Report Share Posted April 15, 2010 you can get a little tool that looks like a C-spanner,its small and cheaps,i used one for ages until i giot the correct tool. Quote Link to comment Share on other sites More sharing options...
psycholist Posted April 16, 2010 Report Share Posted April 16, 2010 (edited) A BB lockring tool will just chew through the edge of the cup of a SKF BB too thanks to the cups being Aluminium and the tool being designed to be used on steel. The tool you need is here AFAIK: http://www.chainreactioncycles.com/Models.aspx?ModelID=995 I've got one in my garage and I'm pretty sure that's what I used fitting an SKF BB to a friend's bike... Edited April 16, 2010 by psycholist Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted April 16, 2010 Author Report Share Posted April 16, 2010 A BB lockring tool will just chew through the edge of the cup of a SKF BB too thanks to the cups being Aluminium and the tool being designed to be used on steel. The tool you need is here AFAIK: http://www.chainreactioncycles.com/Models.aspx?ModelID=995 I've got one in my garage and I'm pretty sure that's what I used fitting an SKF BB to a friend's bike... Doesn't fit as it says on tarty. The LBS had one of those but it's not long enough to go over the axle part. It's too short if you get me. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted April 18, 2010 Report Share Posted April 18, 2010 BIG HAMMER!!!! very very very gentle precise taps with a punch. Quote Link to comment Share on other sites More sharing options...
