trials owns Posted April 9, 2010 Report Share Posted April 9, 2010 hi i was thinking of buying a brake booster. what do they do improve the braking or something?. my mate says i should get one for my frame because it could snap the frame, is this true? cheers Quote Link to comment Share on other sites More sharing options...
josh barker Posted April 9, 2010 Report Share Posted April 9, 2010 here Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 9, 2010 Report Share Posted April 9, 2010 They make your brake stiffer and eliminate frame flex obviously a flexy frame will eventually lead to metal fatigue and that leads to cracks and snaps Quote Link to comment Share on other sites More sharing options...
trials owns Posted April 9, 2010 Author Report Share Posted April 9, 2010 ah i see now, thanks never thought to look there! Quote Link to comment Share on other sites More sharing options...
Geek Posted April 9, 2010 Report Share Posted April 9, 2010 When I personally got a brake booster, I think it was needed, but to be honest I would steer clear of getting one (if you can make do without one) as it can make your brake very annoying to adjust due to the booster limiting the "movability" of the brake. The bike/brake I used it on we're an Onza T-Pro '07 and a Magura HS33. I found that before the booster I could physically see my frame flexing (apparently can cause cracks e.t.c. so I decided to go with a GU booster. to be honest I think this was over kill as I used to keep clipping my shoe on it and it was way too big (making it even more limiting that other boosters). In summary, If I was to go back an buy a different booster, I'd go for something much smaller to stop me clipping my foot and make it much nicer to adjust (and also lighter), possibly a 2-bolt booster. Hope this helps, Charlie Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted April 9, 2010 Report Share Posted April 9, 2010 it can make your brake very annoying to adjust due to the booster limiting the "movability" of the brake. never ever had this problem :/ If you're using 4 bolt mounts and setting up your brake the easy way (the way tarty shows you) it doesn't make any difference at all Quote Link to comment Share on other sites More sharing options...
Arran Posted April 11, 2010 Report Share Posted April 11, 2010 I find the booster (EVO2) help get the brakes over the wide rims if you ride with the 20" 19" inch tyres. Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted April 11, 2010 Report Share Posted April 11, 2010 Also a booster reduces the noise from your brake as it will reduce vibration. Quote Link to comment Share on other sites More sharing options...
trials owns Posted April 12, 2010 Author Report Share Posted April 12, 2010 sweet. might get a 4 bolt booster for some extra stiffness. thanks guys Quote Link to comment Share on other sites More sharing options...
