modifiedridah2k9 Posted April 6, 2010 Report Share Posted April 6, 2010 hey guys i just got out and brake wasnt rubbing. 5 mins later it starts rubbing pretty hard slowing my wheel down. the i go fix it and it is fine becos i loosend the chain tugs. but the rectangle things in front of the chaion tugs were loose. got out without a rub everything perfect, chain tight and brake not rubbing. i go out do a few backhops and my chain is really loose so i go in, tighten chain tugs so rectangle things are tight then really strong rub and wheel barely moves. any help? always does this so can some good bike mechanics lol help me? Thanks Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 6, 2010 Report Share Posted April 6, 2010 What? It sounds like your wheel is moving even though you're using chain tugs. Convert to snail cams. Echo TR ones. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted April 6, 2010 Author Report Share Posted April 6, 2010 What? It sounds like your wheel is moving even though you're using chain tugs. Convert to snail cams. Echo TR ones. do u no where to get some? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 6, 2010 Report Share Posted April 6, 2010 Tartybikes.co.uk Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 6, 2010 Report Share Posted April 6, 2010 do u no where to get some? you can get them from tarty but you would need to get someone to drill holes in your frame for the bolts mate Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted April 6, 2010 Author Report Share Posted April 6, 2010 so rab will that be what it is? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 6, 2010 Report Share Posted April 6, 2010 it sounds that way mate but it never used to be as bad as this. you could try adding another bolt on your chain tugs to act as a lock nut Quote Link to comment Share on other sites More sharing options...
Yorkshire Dale Posted April 6, 2010 Report Share Posted April 6, 2010 Are you actually tightening ur back wheel? daft question but iv done it myself! Quote Link to comment Share on other sites More sharing options...
