Hs33 V-Brake Mounts Set Up Help ?
mckenzietrials
HI there just brought new pads from my REAR hs33 and my old pads were wore so much you could see the plastic caseing.
So o took my wheel off and replaced the pads Onza citrue yellow pads and then i put my wheel back in again and the wheel didnt even budge the pads were too tight so i moved the pads out a bit and it still didnt works so now my wheel is in place with correct chain tension with the whole brake of both sides :(
could some one give me a step by step guide ??
quick as possible ?
thank you mckenzie
have you checked the FAQ section of the forum???
this tread is a good start, you basically just need to re-setup your magura, just by loosening the anchor bolts holding your brake to the frame, move the pistons out accordingly, re-tighten up, a useful tip is use a CD inbetween your rim and pads, get everything square, then tighten it all up, then use your TPA to get the amount of lever pull you desire
for more help, this thread may be of some use to you . . .
rim brake setup tread
