Rowlly21 Posted April 3, 2010 Report Share Posted April 3, 2010 (edited) Hi i was riding today when i started to hear a noise looked over the bike and there was a grinding noise coming from the freewheel? does anyone know what this is ? Edited April 3, 2010 by Rowlly21 Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 3, 2010 Report Share Posted April 3, 2010 what freewheel are you using? Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 3, 2010 Report Share Posted April 3, 2010 Did you used WD40 on it? Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted April 3, 2010 Author Report Share Posted April 3, 2010 what freewheel are you using? not a clue what do you wnat make or what ? Its pretty basic Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 3, 2010 Report Share Posted April 3, 2010 yeah the make so anyone who has had the same freewheel can help you Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted April 3, 2010 Author Report Share Posted April 3, 2010 Did you used WD40 on it? No i havent used WD40 on it rab shropshire do you have a idea what it could be or do you need the make because i cant be botherd to unlock the sheds ! Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted April 3, 2010 Report Share Posted April 3, 2010 if it is one of the freewheels with loose ball bearings, one of the balls may have dislodged and made its way into your pawls and springs. are you able to strip the freewheel? also is the freewheel still working as normal apart from the noise. Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted April 3, 2010 Author Report Share Posted April 3, 2010 yeah working fine just the noise sounds dodgey ill strip it down tomro see whats up Thanks Quote Link to comment Share on other sites More sharing options...
smithy83 Posted April 3, 2010 Report Share Posted April 3, 2010 if its a tensile 96,my lockring came loose a few weeks back and was making a grinding noise as it wasnt running true and had play,i just stripped it down cleaned out ,re greased bearings and a bit of rohloff hub oil on the pawls now works a treat with no problems.duno if any help to you Quote Link to comment Share on other sites More sharing options...
