rab shropshire Posted March 31, 2010 Report Share Posted March 31, 2010 Good evening men and women of the forum. My problem tonight is that I need to change my front hub, I am going from an onza sealed disc hub to an echo tr disc hub. onza spec Hub Dimensions Disc Side: - Flange Diameter: 58mm - Centre to Flange: 22mm Non Disc Side: - Flange Diameter: 32mm - Centre to Flange: 36mm echo spec Hub Dimensions Disc Side: - Flange Diameter: 56mm - Centre to Flange: 25mm Non Disc Side: - Flange Diameter: 30mm - Centre to Flange: 31mm what i need to know is will i need new spokes or can i just do a straight swap cheers RAB Quote Link to comment Share on other sites More sharing options...
josh barker Posted March 31, 2010 Report Share Posted March 31, 2010 very simple: different hubs with different dimensions= different spoke length's Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted March 31, 2010 Author Report Share Posted March 31, 2010 well then does anyone know what length spokes i will need then Quote Link to comment Share on other sites More sharing options...
LordMersey Posted March 31, 2010 Report Share Posted March 31, 2010 Use the DT swiss spoke calculator Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted March 31, 2010 Author Report Share Posted March 31, 2010 Use the DT swiss spoke calculator I just have and the difference between the different hubs is around 3mm. but does this mean my spokes will be fine Quote Link to comment Share on other sites More sharing options...
josh barker Posted March 31, 2010 Report Share Posted March 31, 2010 I just have and the difference between the different hubs is around 3mm. but does this mean my spokes will be fine no spokes stretch, plus their still different length's Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted March 31, 2010 Author Report Share Posted March 31, 2010 no problem mate thanks for the quick replys, new spokes are the order of the day Quote Link to comment Share on other sites More sharing options...
