Alex Dark Posted May 23, 2010 Report Share Posted May 23, 2010 DO NOT WELD IT....you will lose all the tempering around the brake mount Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 23, 2010 Report Share Posted May 23, 2010 DO NOT WELD IT....you will lose all the tempering around the brake mount nowt wrong with welding if you have it heat treated Quote Link to comment Share on other sites More sharing options...
Canardweb Posted May 23, 2010 Report Share Posted May 23, 2010 What I did was getting a bigger bolt in the hole then cut it and drilled a new thread inside... Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted May 24, 2010 Report Share Posted May 24, 2010 help meee was helicoiling my mounts today , as i was drilling one of them out i found it it had been helicoile before but a bigger helicoil was fitted , thats helicoil pulled out now im left with a hold tht is too big for my m5.8 helicoils .... what can i doo ? x Learn english. Or just an idea here, not 100% sure it'll work but how about getting these: http://tartybikes.co.uk/product.php?product_id=11051&category_id=5 and then weld them onto your frame? surely that is a fix? (correct me if im wrong, as im planning on doing it to mine maybe) Im currently using 2 bolts that go through to the other side of the frame, nutted on to keep them in place, looks ugly, but work nonetheless. Steel frame? My suggestion is tap out to M6 and then just file your mounts. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 24, 2010 Report Share Posted May 24, 2010 My suggestion is tap out to M6 and then just file your mounts. Precisely what i did to mine, 3/4 mounts are now m6 on my python. Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted May 24, 2010 Report Share Posted May 24, 2010 If you wanted all the mounts the same then go to a m6 and helicoil the lot job done. Quote Link to comment Share on other sites More sharing options...
