modifiedridah2k9 Posted March 28, 2010 Report Share Posted March 28, 2010 just not sure wat to use on my rim.wen i land on the edge of my curb,it just slips back? is this the brake or am i not pulling it hard enuff becos i just gt it grinded 2 days ago little help cheers Quote Link to comment Share on other sites More sharing options...
Mikee Posted March 28, 2010 Report Share Posted March 28, 2010 What pads are you using? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted March 28, 2010 Author Report Share Posted March 28, 2010 What pads are you using? heatsinks Quote Link to comment Share on other sites More sharing options...
Mikee Posted March 28, 2010 Report Share Posted March 28, 2010 heatsinks Are you using CNC backings? Are they set up perfectly square? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted March 28, 2010 Author Report Share Posted March 28, 2010 Are you using CNC backings? Are they set up perfectly square? think so. ask Rab-shropshire Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 28, 2010 Report Share Posted March 28, 2010 Crap grind? Not bedded in? Poorly set up? Poor bleed? Could be many many things. But certainly a grind over tar. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted March 28, 2010 Author Report Share Posted March 28, 2010 Crap grind? Not bedded in? Poorly set up? Poor bleed? Could be many many things. But certainly a grind over tar. pretty sharp grind,bled it today wi water but wat is beddid in? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted March 28, 2010 Report Share Posted March 28, 2010 bedded in is like i explained to you mate, the bleed is good and the brakes were set up fine i will have a look at it all tommorrow and see if anything may have just moved out of allignment Quote Link to comment Share on other sites More sharing options...
