Www.Easy-Bike.Cn
Mr Clayton
:) Hey guys, was speaking to Cao this morning from easy-bikes.cn
He showed me there latest design of the Fans frame and i thought you may all like to see for when it is available to buy!
Heres the pictures and a little write up about the frame and how its been improved from the previous FANS
Wooo,the FANS EVO really takes us a long time to redesign and testing...
We changed the CNC parts on the frame,that made them have more
practicability,get more powerful.
A lots of riders prefer the frame with the bashplate,as you can see,this time
we have added the bashplate design(not supply with the frame),large "A"
CNC parts design on the rear stay.New EVO HS33 version also added the
brake booster,with the 2-section design.
If you
http://img156.imageshack.us/img156/9035/evoe.jpg
If you watched carefully,you will see that we also changed the rear up tube
into one piece!
The main GEO of FANS EVO.
We changed the material on new EVO,to use U6 instead of 6061 alloy,so the
weight won't be added.
Disc Version:1.49Kg.
HS33 Version:1.58Kg.
Both of the versions are available in Matte Black and Gun Smoke colours.
For more info,just feel free to contact us to know more!
EASY
Also they are currently designing/making new products which hopefully sometime soon I shall be testing
Will do my best to keep you all up to date!
Thanks Ross :)
  • 2 months later...
RC 345..OH MY GOD..that will be f**king bunyyhop machine
It would be 350 though, because 18:12 ratio doesn't work with 345mm...
We looked into these frames a while back - the price is quite a bit more than the original frame and it's heavier, so we didn't think they'd sell too well?
So is this frame out now ?
and is the added weight in the HS33 model not just from the built in booster ?
