Jay* Posted March 26, 2010 Report Share Posted March 26, 2010 I've just fitted a new 203mm rotor to my front Hope brake. When I hold the brake on and move back and forth, it rocks. All the bolts are tight, but it looks as though the disc moves on the hub (which is a Hope). Anyone else had this issue or know of a fix? Quote Link to comment Share on other sites More sharing options...
Slobert Posted March 27, 2010 Report Share Posted March 27, 2010 I am not familiar with hope disc brakes, but I have used many others on my Mountain bikes, and depending on how much movement you are talking about, you are probably just feeling the pads move. Most pads have some freeplay. For some reason I notice this more with 203mm rotors. Possibly its the extra leverage they have against the pads. On most of my bikes, its just enough freeplay to feel like a loose headset when you move the front tire back and forth with the front brake on. If you are feeling more movement than that, then you have a problem. If the movement only started after putting on a new / larger rotor, then maybe the pads were not put in properly or the rotors not torqued down. Quote Link to comment Share on other sites More sharing options...
Dec Whiteoak Posted March 30, 2010 Report Share Posted March 30, 2010 i had that problem,all i did was took the existing bolts out put lockite on them,and screwed them back in and left them to dry hope this helps Quote Link to comment Share on other sites More sharing options...
