martin555 Posted March 24, 2010 Report Share Posted March 24, 2010 I had a 160mm rotor on the back of my Hydroxx short but couldn’t get it to work no matter how it was set up. So now I’ve finally got this issue resolved and have a 180mm rotor on the back that works but I have to pull the lever nearly all the way to the handle bar to get a good locked break feeling is there anyway of altering this? Could it be that it needs some more break fluid in it? Also does anyone know where I can by a matching 180mm Magura rotor for the front and also a mount? As my bike looks ridiculous with a gigantic rotor on the back and a tiny one on the front. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted March 24, 2010 Report Share Posted March 24, 2010 sorry dude but lol next time get rear magura Quote Link to comment Share on other sites More sharing options...
martin555 Posted March 24, 2010 Author Report Share Posted March 24, 2010 (edited) sorry dude but lol next time get rear magura I have got a rear magura MAGURA LOUISE! anyone got any helpfull ideas? Edited March 24, 2010 by martin555 Quote Link to comment Share on other sites More sharing options...
onzatrip Posted March 24, 2010 Report Share Posted March 24, 2010 okay then hs33 answer your phone Quote Link to comment Share on other sites More sharing options...
martin555 Posted March 24, 2010 Author Report Share Posted March 24, 2010 (edited) I cant lol its in my locker at work Edited March 24, 2010 by martin555 Quote Link to comment Share on other sites More sharing options...
onzatrip Posted March 24, 2010 Report Share Posted March 24, 2010 you dousch some advice sent it back to tarty (mean the whole bike) Quote Link to comment Share on other sites More sharing options...
FINDUS Posted March 24, 2010 Report Share Posted March 24, 2010 I had a 160mm rotor on the back of my Hydroxx short but couldn’t get it to work no matter how it was set up. So now I’ve finally got this issue resolved and have a 180mm rotor on the back that works but I have to pull the lever nearly all the way to the handle bar to get a good locked break feeling is there anyway of altering this? Could it be that it needs some more break fluid in it? Also does anyone know where I can by a matching 180mm Magura rotor for the front and also a mount? As my bike looks ridiculous with a gigantic rotor on the back and a tiny one on the front. You need to re bleed the brake!! it needs more fluid but make sure you have the adjustment on the lowest setting to allow more fluid into the system. is this the bat louise? if so have look on the magura website for bleed info as its very long winded and strange Quote Link to comment Share on other sites More sharing options...
martin555 Posted March 24, 2010 Author Report Share Posted March 24, 2010 nah its not the bat louise its the more standard one with out the red adjuster on the front. Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted March 24, 2010 Report Share Posted March 24, 2010 If its set up perfectly square and its still spongey, then you have some air in the system. If its just pulling to the bar because of lever flex then try bleeding it with the pistons slightly out (1 or 2mm each side should do it). Quote Link to comment Share on other sites More sharing options...
