Pad Material Swaps
tdubz
Hello
i currently have a pair of tnn v brake pads with the tnn cnc backings
i was looking at maybe som heatink pads or maybe some phatpads next when these wear out
can i fit heatsink/phatpads into tnn backings or will i have to buy the whole unit again
thanks
thomas
I've fitted TNN pads into Heatsink backings, but the TNN ones are slightly longer than heatsinks, so it was just a matter of cutting the pad down a little to fit the backing. Not sure how well it would work the other way around. This was for Magura backings though the V ones take the same pads AFAIK.
I run Koxx Brown material in TNN backings, its a relatively easy thing to do. The ends of each bit that insert into the backing need trimming down and maybe the center bit, but thats it, takes about 2 minutes to trim the material from the powerpad backings to fit the TNN cnc backings.
